pics of what happened to my car
Timing belt
Bolt that did all the damage
Where the bolt is supposed to be from the water pump
Where the bolt got stuck on the valve cover
Crank position censor BROKEN
I had the water pump and belt replaced a year ago by a local shop, hmmm I wonder if they ever thought to tighten the bolt
fu*k me
fu*k me
Crazy dude, It sucks when stuff like this happens, I always like to go over anything a shop does and double check anything they mess with.
i wasnt even goin fast or anything, i just want my car to look good, not break, damnit, i just want it fixed
Did you hear the belt shreading or did the engine just stop??? If it just stopped then you might of bent some valves. I had a belt break and nothing ahppened, but i was luckey! If you heard it then you might not of damaged anything.
I had something somewhat similar happen to me last year. About 6 months after doing a timing belt, water pump, tensioner replacment I started to hear an odd noise. Sounded like the bearings in the alternator were going. Something was bouncing around inside the belt/pump area. AFter taking it to a shop, I found out teeth had somehow broken off of the water pump pulley. That's what I get for buying a non-OEM pump. Lesson learned.
I'd go and complain to that shop. Just bitch at them, tell them what a poor job they did and you'll be getting the word out in the area...and obviously never take your car there again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stasi »</TD></TR><TR><TD CLASS="quote">I had something somewhat similar happen to me last year. About 6 months after doing a timing belt, water pump, tensioner replacment I started to hear an odd noise. Sounded like the bearings in the alternator were going. Something was bouncing around inside the belt/pump area. AFter taking it to a shop, I found out teeth had somehow broken off of the water pump pulley. That's what I get for buying a non-OEM pump. Lesson learned.
I'd go and complain to that shop. Just bitch at them, tell them what a poor job they did and you'll be getting the word out in the area...and obviously never take your car there again.</TD></TR></TABLE>
what shop was this??????...oh and some after market pumps arent bad,,,,iuno, if never had a problem with em
well i know this sucks but i never heard anything it just stopped, some of the belt rapped around the part that turns the crank and thats why it stopped, I will call the shop tomorrow to see whats going on.
fryman
25
Jun 25, 2017 05:31 PM
MC Slide Hammer
Mar 23, 2011 02:25 PM
Shaguar47
May 26, 2007 09:40 AM
