Custom trunk traction bar
Old Jun 11, 2005 | 09:54 PM
romoracing's Avatar
Default Custom trunk traction bar
Hi,
Well it might not make sense to you but I want to make a custom rear strut bar. But today I was cleaning out my trunk and i took out the carpet and the plastic thing that goes around the hook to keep the trunk closed. (1999 civic coupe) and I found 2 holes for screws. So I was thinking if I would make a strut bar with 2 bars comming from it to those 2 holes. Pretty much like a traction bar for your trunk. Heres a pic I made in photoshop. Yes, I know it looks like trash and its not even the same year civic. Its just to show you what I mean:
Well my question is well the extra bars help or is it a waste of time and effort?
Old Jun 11, 2005 | 10:15 PM
blueoval557's Avatar
Default Re: Custom trunk traction bar (romoracing)
Romo, great idea! Its not necassarily(sp?) a traction bar for your trunk, but a triangulated rear strut bar. You will see these on some nice front strut bars. As for whether or not it would work, absolutely. You couldnt make anything better. The triangle is the strongest isometric shape, besides the circle which cannot usually not be made in any projects, therefore, this would be the best you could get. Onyl concern...at one point you called the holes in the trunk for "screws", then you called them "bolts"....which is it? Screws would probably be pointless....if they are BOLT HOLES, then GREAT! Now get to work! Haha. Good Luck!
Kyle
Old Jun 12, 2005 | 08:27 AM
romoracing's Avatar
Default Re: Custom trunk traction bar (blueoval557)
Sry it was late last night. In going to bolt it into the frame. This is the hole ill be using:
Well im going to go get started ill update you guys on how it goes.
Old Jun 12, 2005 | 10:16 AM
Bakeoff's Avatar
I have a very similar designed bar that my buddy and I made last summer. I'll try to post some pics later. I have to say that it kicks ***, getting that rear end tied together. The bad thing is, if you get rear ended, you know it will push your shock towers forward, and the car is toast...
Old Jun 12, 2005 | 12:38 PM
romoracing's Avatar
Default Re: Custom trunk traction bar (Bakeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">I have a very similar designed bar that my buddy and I made last summer. I'll try to post some pics later. I have to say that it kicks ***, getting that rear end tied together. The bad thing is, if you get rear ended, you know it will push your shock towers forward, and the car is toast... </TD></TR></TABLE>
Im not that worried. I dont drive it to much and this x-mas i want to get a cage put in that goes onto the shock tower.
Old Jun 12, 2005 | 04:06 PM
romoracing's Avatar
Update. This is for the ppl that dont know what im talking about.
this is just to show how im going to do it. the tower bar is just there for picture purpose and will be replaced.
Old Jun 15, 2005 | 04:37 PM
Leets's Avatar
how much angle are you getting on the bars that connect to the rear? It seems as if it's creating more of a box shape when a triangle would be more ideal. Still, awesome custom idea... makes me want to get off my lazy butt and learn to weld already.
Old Jun 17, 2005 | 08:30 PM
romoracing's Avatar
Default Re: Custom trunk traction bar (Leets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leets &raquo;</TD></TR><TR><TD CLASS="quote">how much angle are you getting on the bars that connect to the rear? It seems as if it's creating more of a box shape when a triangle would be more ideal. Still, awesome custom idea... makes me want to get off my lazy butt and learn to weld already. </TD></TR></TABLE>
To tell you the truth im not sure. if i were to guess i would say 55-65%. The Bolt hole were not aligned perfectly so the one on the right is off alittle. Heres the bar done: (Im going to go pick up some pipe covers soon)
You should get up and learn its fun and the bar works. I can take turns alot better now!!!
JL_DC5
Jan 10, 2009 06:20 PM
Nicks95GSR
Feb 29, 2008 04:13 PM
Fomoco
Feb 6, 2007 01:50 PM
Blue Si #72
Dec 20, 2003 12:22 AM
Drag-On
Feb 13, 2003 09:42 AM
