Greddy TT plus OEM Alarm
i searched and didn't find the answer i was looking for. I would like to know if it is possible to wire up a TT and an OEM alarm so that everything works the way it should. the only thred i found was from 2001 with a dead link. https://honda-tech.com/zerothread?id=59777
does anyone have a newer link for this?
also i know that for alarms that are not factory, you have to use a 5 point relay. will i have to do that with the OEM one as well?
Most aftermarket alarms will have an input to disable the ign. sense and impact sen. for turbo timers or remote starts, and most remote starts have oem alarm control, and turbo timers built in, I don't know if your Greddy has "oem alarm control" but as the oem alarm does not have an impact sen. all you should have to do install a relay on the ign. input of the oem alarm, so that when the TT is on it will "trigger" the relay to open, so the alarm does not see ign. because you didn't say what car it was going into, that's all the help I can give you now.
94
94
John M
Mar 31, 2008 07:49 PM
