short shifter rattles
Old Jun 11, 2005 | 06:02 PM
94integragsr's Avatar
Banned
Default short shifter rattles
anyoneelse have this problem i have also replaced bushings with new poly ones
Old Jun 11, 2005 | 06:32 PM
Lord Helmet's Avatar
Default Re: short shifter rattles (94integragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integragsr &raquo;</TD></TR><TR><TD CLASS="quote">anyoneelse have this problem i have also replaced bushings with new poly ones </TD></TR></TABLE>
What kind is it?
Old Jun 12, 2005 | 10:33 AM
Banned
Default Re: short shifter rattles (Lord Helmet)
b&M so i replaced it with a ractive and it still does it
Old Jun 12, 2005 | 10:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integragsr &raquo;</TD></TR><TR><TD CLASS="quote">b&M so i replaced it with a ractive and it still does it </TD></TR></TABLE>
The bushings is not the issue. The bearings on the short shifter is what is causing the rattling sound. I use to have B&M SS. It requires you to reuse the stock bearings which are a little smaller. That is what is causing the rattling sound.
When I switched to the Skunk2 with it's own sealed bearings. The rattling sound is gone.
Old Jun 12, 2005 | 11:19 AM
B18ls*RAYON's Avatar
You may also find that short shifters tend to touch the shield on the CAT. This can cause a rattle.
Old Jun 12, 2005 | 03:04 PM
ecks_fourttwo's Avatar
Default Re: short shifter rattles (B18ls)
^^^^true
Old Jun 12, 2005 | 04:17 PM
Banned
Default Re: short shifter rattles (ecks_fourttwo)
thanks for the imput the ractive one that i replaced the b&m with has sealed bearings and it does not do it all the time only when down shifting and high acceleration /
Old Jun 12, 2005 | 04:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94integragsr &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the imput the ractive one that i replaced the b&m with has sealed bearings and it does not do it all the time only when down shifting and high acceleration /</TD></TR></TABLE>
reactive still isn't a quality part to begin with. They are like APC BTW not all sealed bearings on SS & short shifter themselves are built equally.
Old Jun 12, 2005 | 05:33 PM
Banned
very true
Old Jul 8, 2005 | 08:34 AM
Gekko's Avatar
Default Re: (94integragsr)
I have a B&M shifter and get the same annoying rattle. Anyone figured out how to fix it without just getting a different shifter? By the way it's on a DA integra.
honda_coupe
24
Apr 26, 2007 08:46 PM
97RSTEG
Jul 14, 2006 09:40 PM
wildman117
Feb 15, 2006 07:36 AM
hotdoggies
10
Mar 1, 2005 04:35 PM
beaterman
Apr 24, 2003 09:03 PM
