Need Help Please, head gasket leak.....AGAIN!!
Old Jun 11, 2005 | 04:56 PM
StuPid oNe's Avatar
Default Need Help Please, head gasket leak.....AGAIN!!
I took my car to the shop to fix a head gasket leak and got it installed, when I got it back it idled like ****...from 600 down to 100 rpm and almost dies.
And I just check under the oil cap and it's milky again?? wassup with that.
I just bought a new OEM gasket and it's milky again.
It's throwing a CEL 6..ECT code.
Any advice anybody??
GSR Skunk2 cams, valvetrain
Old Jun 11, 2005 | 06:00 PM
Sam92Teg's Avatar
Default Re: Need Help Please, head gasket leak.....AGAIN!! (StuPid oNe)
Was your car overheated recently? Could have a warped head on your hands. The shop should have checked for this. Lets hope its not something worst like a cracked cylinder.
Old Jun 11, 2005 | 11:27 PM
StuPid oNe's Avatar
it never over heated, how do you know if it's a warped head?
Is it fixible and what causes it?
Old Jun 13, 2005 | 06:16 AM
StuPid oNe's Avatar
any experts out there?
Old Jun 14, 2005 | 02:53 PM
StuPid oNe's Avatar
Nobody can help me huh?
Old Jun 14, 2005 | 03:09 PM
92Jspec's Avatar
to check if its warped you have to take the head off and run a straight edge over it. did the shop resurface the head before the install? if it is warped you might be able to just get it resurfaced if its not warped too bad. hope that helps.
Old Jun 14, 2005 | 03:41 PM
327da9's Avatar
Check your dipstick to see if the oil is milky too, because sometimes the assembly lube used on the cam is white and when mixed with the oil it looks milky like coolant mixed with it.
What is your head/block setup and which head gasket did you use?
Old Jun 14, 2005 | 04:04 PM
StuPid oNe's Avatar
Default Re: Need Help Please, head gasket leak.....AGAIN!! (327da9)
Yeh I'm gonna take it back to the shop that worked on it, what causes it to warped though?
I used new oem head gasket.
E-AH driver
Classic Hondas
Jan 23, 2012 03:53 AM
futurefastguy
Jul 13, 2009 09:29 PM
john457
Jun 5, 2007 05:25 PM
vtec93accord
Jan 3, 2004 05:11 PM
