Suspension & Brakes Theory, alignment, spring rates....
Coilovers for my EG
Old Jun 11, 2005 | 02:39 PM
ferchoz's Avatar
Default Coilovers for my EG
I would like opinions between this three brands of coilovers, which one is better: Tenzo R, Arospeed or DropZone. Thank you.
Old Jun 11, 2005 | 03:16 PM
ferchoz's Avatar
Default Re: Coilovers for my EG (ferchoz)
any one? i would really appreciate if you guys give me an answer...Thank you
Old Jun 11, 2005 | 03:37 PM
tzonni's Avatar
are you just daily driving and want to lower it?? or do u want better handling???
Old Jun 11, 2005 | 03:45 PM
ferchoz's Avatar
Default Re: (tzonni)
why? whats the difference? i want better handling, but ima be daily driving the car too
Old Jun 11, 2005 | 06:13 PM
ferchoz's Avatar
Default Re: (ferchoz)
any logical opinions?
Old Jun 12, 2005 | 04:05 AM
03shadow's Avatar
i would go with neither and grap a pair of ground controls
Old Jun 12, 2005 | 06:40 AM
Zman15's Avatar
DO NOT SKIMP on suspension. You'll only end up replacing it later and wasting money. If you want coilover sleeves, get yourself some Ground Controls and some decent shocks.
Latez,
Paul
Old Jun 12, 2005 | 07:35 AM
ferchoz's Avatar
Default Re: Coilovers for my EG (Zman15)
like....what kind of ground control?
Old Jun 12, 2005 | 02:01 PM
03shadow's Avatar
get some koni adgustables like gr2 or agx and put the ground control coilovers. i promise you bro you wont regret it. i had ground controls on my eg and it had handles.
Old Jun 12, 2005 | 02:11 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Ser-ace)
For the money, you cannot beat a set of Koni sport (yellows) shocks, and a set of Ground Control Coilover sleeves. You can choose from any spring rate that eibach makes (on your coilovers), and it only costs a tiny bit extra. Also, GC coilovers and Koni shocks are warranted for life and have the best customer service in the biz...
Old Jun 12, 2005 | 03:39 PM
ferchoz's Avatar
Default Re: (94eg!)
damn thanks a lot
Old Jun 12, 2005 | 05:00 PM
turnbuckle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">For the money, you cannot beat a set of Koni sport (yellows) shocks, and a set of Ground Control Coilover sleeves. You can choose from any spring rate that eibach makes (on your coilovers), and it only costs a tiny bit extra. Also, GC coilovers and Koni shocks are warranted for life and have the best customer service in the biz...</TD></TR></TABLE>
Old Jun 12, 2005 | 07:59 PM
ferchoz's Avatar
and how much would that all be?
Old Jun 12, 2005 | 08:35 PM
crxmadman's Avatar
http://cgi.ebay.com/ebaymotors...=WDVW
check that out ^^ OR you can order from GC directly
https://honda-tech.com/zerothread?id=1093669
nolimit's sale on koni's free shippin
Old Jun 12, 2005 | 09:18 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Coilovers for my EG (crxmadman)
Should be around $800-$850 shipped for Koni Sports & GC coils. Just make sure you order Ground Control sleeves that are specifically made for Koni shocks (they have a special mounting style).
Old Jun 13, 2005 | 05:29 PM
ferchoz's Avatar
But damn! thats a lot of money....
Old Jun 13, 2005 | 05:32 PM
cbmprelude's Avatar
* B A N N E D *
better to buy that now, then to buy cheap stuff now and then the good stuff later itll cost more
Old Jun 14, 2005 | 07:44 AM
ferchoz's Avatar
Default Re: Coilovers for my EG (cbmprelude)
well thats true, but what is so bad about the coilovers, just to lower the car, i know i need to get some camberkits too... butt...
Old Jun 14, 2005 | 08:08 AM
94eg!'s Avatar
#1 Super Guy
Loved
I drove around on GC coilovers (lowered about 3") for almost 5 years with stock shocks. I never had a problem with my shocks blowing out or anything, but I always drove extra carefull. Plus, streets here in Vegas are relativly nice. I never got a camber kit, and I don't really feel that they are necissary either. As long as you get an alignment after you lower it, your tires will not wear on the inside (it's bad toe settings that wear your tire edges). Plus you get increased cornering ability with added negative camber. I also think that changing the length of UCAs messes up the factory suspension geometry (that why they are non-adjustable), and increases the vehicles bump-steer. No I don't have any evidence to back that one up...
Getting sleeves first will end up costing you more money in the long run (even if you do the work). This is because the sleeves for OEM style shocks, & Koni shocks, are completely different. If you ever switch to Koni shocks, you will need to purchase new GC sleeves, and re-use your old GC springs. The Koni shocks have a special spring perch that sits on an adjustable snap ring. The snap ring can be raised or lowered to adjust ride hieght. The GC sleeves for Koni shocks are designed to sit directly on the snap ring instead of the spring perch (like the OEM style ones). Koni says you cannot use coilover sleeves unless they sit directly on the snap ring otherwise you will eventually experience catastrophic spring perch failure (as seen in this thread).
I went this route though, and I was very happy overall. It ended up costing about $100 extra, but I then sold my old sleeves for $30 a pair, so I'm only out $40...
Old Jun 14, 2005 | 08:10 AM
ferchoz's Avatar
Default Re: Coilovers for my EG (94eg!)
Thats what im talking about
sol_1
Jun 17, 2006 01:46 PM
skynyrd006
Jun 12, 2006 05:00 PM
sslude
May 25, 2003 11:06 PM
VTECTIME
50
Oct 25, 2002 03:39 PM
se93
Mar 30, 2002 11:44 PM
