stock radio code
What year is your car?? If i remember all u have to do is type in the code with the number pad where you set your radio. I kno the radio wont work unless you put in the code. I dont think there is a menu it should pop up asking for your code right away. If their are letters you should be able to scroll with the volume or seek buttons i think?? But yea u should just try that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 »</TD></TR><TR><TD CLASS="quote">What year is your car?? If i remember all u have to do is type in the code with the number pad where you set your radio. I kno the radio wont work unless you put in the code. I dont think there is a menu it should pop up asking for your code right away. If their are letters you should be able to scroll with the volume or seek buttons i think?? But yea u should just try that. </TD></TR></TABLE>
its a 94, so when it says code, just type in the 5 numbers. and go?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esracer »</TD></TR><TR><TD CLASS="quote">yeah, it didn't work. I think the radio might be trash</TD></TR></TABLE>
Did it make a beep as you put in the 5th number?
after inputting wrong code 3 times radio goes intoa lock down state,, remove battery cables let is sit for a few minutes and retry inputting code ..assuming you got the right code it should work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esracer »</TD></TR><TR><TD CLASS="quote">the radio has never beeped @ me, hummmm?</TD></TR></TABLE>
Just take your radio to Honda and they should give you the correct code....
