what direction
noob question, just replaced cap and rotor.
which direction does the cylcnders go? from left to right, is it 4-3-2-1? (if looking in front of the car)
i know the cap goes like this
i mean on the valve cover part not the dizzy cap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote">
I've been using that one for a while, works good. Worked on the D16 and works on the DOHC ZC the only difference is the DOHC ZC's dist is rotated about 190-200 degrees.
</TD></TR></TABLE>I've been using that one for a while, works good. Worked on the D16 and works on the DOHC ZC the only difference is the DOHC ZC's dist is rotated about 190-200 degrees.
93SSPHatch
May 31, 2002 04:13 AM
I concur
