reset ecu after each mod?
Old Jun 11, 2005 | 01:05 PM
redDAinteg's Avatar
Default reset ecu after each mod?
i was told by a friend that its better to reset the ecu after you put parts on your car so your car will notice you have different parts. Is this necessary and is their any out come of this ? just curious.
Old Jun 11, 2005 | 02:41 PM
zeroz's Avatar
Default Re: reset ecu after each mod? (redDAinteg)
hmm i'd like to know also
Old Jun 11, 2005 | 04:47 PM
redDAinteg's Avatar
bump
Old Jun 11, 2005 | 07:05 PM
gsrious's Avatar
no... you really don't have to.
although, you could if you want. you really won't gain much, if any at all.
Old Jun 12, 2005 | 05:41 PM
stumpyf4's Avatar
Depend on the mod. If engine related, intake/exhuast the fuel trim will be reset and the ECU will relearn new values. The ECU continually adjusts so if you don't you'll still end up with the same result down the road.
Old Jun 12, 2005 | 07:20 PM
iH8RICERZ's Avatar
Default Re: reset ecu after each mod? (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Depend on the mod. If engine related, intake/exhuast the fuel trim will be reset and the ECU will relearn new values. The ECU continually adjusts so if you don't you'll still end up with the same result down the road.</TD></TR></TABLE>
EXACTLY. You dont necessarily "have to" do it, but it never hurts. After doing big mods... ie. cams, manifold, etc. then I would reset the ecu.
Old Jun 12, 2005 | 11:28 PM
redDAinteg's Avatar
Default Re: reset ecu after each mod? (iH8RICERZ)
wow interesting.
Old Jun 12, 2005 | 11:53 PM
TurboSC's Avatar
totally out of the blue newb question:
I hear the code to reset the ECU is on the trunk lid? wtf.
and how do you go about resetting it.
Old Jun 13, 2005 | 11:52 AM
xteg95's Avatar
Default Re: (TurboSC)
i would just cause it takes 10 mins. just disconnect the negative from the battery for a couple mins...reconnect it, start up the car (do not press gas or anything), wait til fans start going, shut off car...turn car back on and your ready to drive.
Old Jun 13, 2005 | 09:54 PM
redDAinteg's Avatar
Default Re: (xteg01)
umm dont you have to remove the 7.5 backup fuse under the hood to reset the ecu?
Old Jun 13, 2005 | 10:00 PM
Monkey Z.'s Avatar
what you do to reset the ecu is remove the ecu and ecu backup fuse from the fuse box under the hood...put them back in and run car for about 10 min.
egbaby
Feb 24, 2008 12:30 AM
jerkof1
Aug 22, 2005 10:35 AM
JLSIII
Jul 2, 2003 01:18 AM
Rukusmasta2
Feb 17, 2003 03:01 PM
SOHC_MShue
Oct 14, 2002 11:22 AM
