Why wont my car start?
'85 crx OBDI b16a xsi motor.
Ive been having some clutch problems which Ive narrowed down to the either the pressure plate or throwout bearing.
But now the car wont even turn over. I get one loud click from the starter and thats it.
Heres the thing. The car has ALWAYS started in neutral withOUT the clutch engaged so I have no clue as to why it wouldnt start now?
Any thoughts or explanations?
I WOULD say that your PP isnt releasing your clutch, causing the flywheel to not turn when the starter is engaging.
But you said it would start in Neutral. so Im at a lost. Can you push start it???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n »</TD></TR><TR><TD CLASS="quote">I think you are on the right track. I cant even try to push start it because Im on a hill and if it doesnt work I am royally fu**ed </TD></TR></TABLE>\
u can try to push start it in reverse but u might end up at the bottom of the hill with no way up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX »</TD></TR><TR><TD CLASS="quote">\
u can try to push start it in reverse but u might end up at the bottom of the hill with no way up</TD></TR></TABLE>
Exactly and I really dont want that to happen. Anyone else with an idea on what it could be?
He never had a problem with his starter until this clutch issue. So its highly unlikely, but a possibility. If his starter went the same time his clutch did, he should take four
