b16a into hatch ecu wiring?
Old Jun 11, 2005 | 10:49 AM
HxCforever's Avatar
Default b16a into hatch ecu wiring?
to make a long story short im doing a b16 swap. i got all the wires from the sensors threw the fire wall and ready to go to the ecu. the harness already has pins in the slots. do i just splice into those wires or do i take the pins out and put the sensor wire connected to a new pin in there? tried searching but couldn't find my answer.
*edit* forgot to mention its a 90 si hatch
Old Jun 11, 2005 | 01:06 PM
crx-treme's Avatar
Default Re: b16a into hatch ecu wiring? (dirtydreds)
http://www.hasport.com/Tech/Wring/EFSi-VTEC.PDF
i believe two wires u cut and splice, two u replace the pins, hope this helps
Old Jun 11, 2005 | 03:20 PM
HxCforever's Avatar
kinda helped
Old Jun 11, 2005 | 04:28 PM
HxCforever's Avatar
ok got all the other wires conected but can't figure out were this one goes
doesn't say nuttin about it on the diagrams i got so i'm starting to believe it's a ground. i dwouldn't know so i'm asking the h-t community
Old Jun 11, 2005 | 05:34 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (dirtydreds)
Pressure switch
http://b16a.honda-perf.org/theswap.html
Click on the words and it shows a picture...
Read about o2 sensor wiring otherwise you will hook it up backwards:
https://honda-tech.com/zerothread?id=637661
Old Jun 11, 2005 | 05:38 PM
HxCforever's Avatar
i used that sheet from katman to do all the other wires. the blue and black wire on the pressure switch goes to b5 but were does the black wire connect to
Old Jun 11, 2005 | 05:41 PM
88DXCRX's Avatar
Put a ring terminal on it and ground it to the thermostat housing...
Old Jun 11, 2005 | 05:43 PM
HxCforever's Avatar
are you certain it's a ground?
Old Jun 11, 2005 | 05:50 PM
88DXCRX's Avatar
Yes..I looked at my car just to make sure..
It needs power and ground to complete the circuit..
Old Jun 11, 2005 | 06:00 PM
HxCforever's Avatar
cool i did a quick search as found that it is a ground. thanks again man
carlos1890
Jun 28, 2012 02:22 PM
Suck my DX
21
Aug 23, 2005 06:26 PM
folta2169
Apr 10, 2005 12:35 AM
Bseriesy0
Sep 21, 2004 10:14 AM
98AccordEX
Oct 2, 2003 11:19 PM
