best cams for a d16z6
Old Jun 11, 2005 | 09:45 AM
LudeJdm's Avatar
Default best cams for a d16z6
what are the best cams to run in an ef w/d16z6 w/only bolt ons????
Old Jun 11, 2005 | 10:46 AM
Redline130's Avatar
Default Re: best cams for a d16z6 (lbautista23)
There may not be a definite answer for your question. The stock cam maybe the best. I'm sure there are others who have had success using the ZEX street cam or Crower's stage 1 cam. Best way to find out is to find dyno charts and compare the different cams, but even then you may not find the right cam, since each motor could/can react differently, depending on the tune.
Old Jun 11, 2005 | 10:51 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lbautista23 &raquo;</TD></TR><TR><TD CLASS="quote">what are the best cams to run in an ef w/d16z6 w/only bolt ons????</TD></TR></TABLE>
are you looking for a street or racing application?
Old Jun 11, 2005 | 10:57 AM
baked_beanz's Avatar
bullfrog
Old Jun 11, 2005 | 11:58 AM
LudeJdm's Avatar
Default Re: (baked_beanz)
street
Old Jun 11, 2005 | 12:30 PM
Default Re: (lbautista23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lbautista23 &raquo;</TD></TR><TR><TD CLASS="quote">street </TD></TR></TABLE>
than any "mild" street type should be fine. you should only be concerned for getting the "best" cam if you're running some kinda special race motor. crower, gude, pyr, regrinds, etc... are all pretty good. next question would be how much are you looking to spend, that should narrow your search down to only a few of them
Old Jun 11, 2005 | 03:08 PM
LudeJdm's Avatar
Default Re: (DELSOLEMITE)
im tryn not to spend over $200....if so less than 250
Old Jun 11, 2005 | 03:22 PM
boosted_hatch_216's Avatar
check out exospeeds cam, http://www.exospeed.com
Old Jun 11, 2005 | 04:52 PM
EJ2-Fluffy's Avatar
Default Re: (rexwreck)
Zex 59300 Street/Strip Performance Camshaft http://www.powerandperformancenews.com/store/merchant.mvc?Screen=PROD&Product_Code=59300&Catego ry_Code=&Store_Code=ZX
Or get a delta cam regrind. Exospeed is also another good choice.
Old Jun 11, 2005 | 05:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexwreck &raquo;</TD></TR><TR><TD CLASS="quote">what about obx's skunk2 copy? read a looong thread about them and people that actually had them said they were great..</TD></TR></TABLE>
dont even **** with obx's stuff its ****, i wouldnt be surprised if the cam broke in half and you floated a valve.
98formulaLS1
Mar 9, 2009 09:23 AM
em1boy
Jul 4, 2008 08:10 AM
wing
Jan 2, 2005 03:54 PM
GdmLaz
Dec 16, 2004 09:21 PM
