CRX Si and SiR Hubs
Old Jun 11, 2005 | 07:28 AM
SwissChEz82's Avatar
Default CRX Si and SiR Hubs
I'm trying to find out what the difference is between a CRX Si hub and a JDM SiR hub. I know the disk size is different but what else, is there a different spline count? Are they compatible with the 90-93 Integra axle like the Si hubs are?
Old Jun 11, 2005 | 07:39 AM
Crx Jimmy's Avatar
Default Re: CRX Si and SiR Hubs (SwissChEz82)
yes they are compatable, just get the integra ones they are the same ****,
Old Jun 11, 2005 | 07:41 AM
PURPLETERROR aka BIGMATT's Avatar
the sir hub is pretty much the same as the 90-93 integra hubs, ad the 90-93 integra axles will work fine
Old Jun 11, 2005 | 08:48 AM
bagpipe goatee's Avatar
are you meaning the whole knuckle, or just the hub? the hubs are the integra hubs, but the knuckle is the correct height.
Old Jun 11, 2005 | 09:28 AM
Tyson's Avatar
the SIR knuckles have different tie rod steering geometry.
Old Jun 11, 2005 | 09:37 AM
true, but can't you just get around that by shortening/tapping your inner tie rods?
Old Jun 11, 2005 | 09:52 AM
Tyson's Avatar
Default Re: (bagpipe goatee)
i actually dont know what the difference is. i just know its different.
Old Jun 11, 2005 | 09:58 AM
JapJunkie's Avatar
Default Re: (Tyson)
What are the size difference between the rotors on DA and JDM EF?
turkishEF
Jul 6, 2010 05:36 PM
Devil CRX
Oct 8, 2009 09:33 AM
baker_jeff
Apr 19, 2006 07:43 AM
ricodemus
May 24, 2002 04:42 PM
