JDM foglights EG6 ?????
Toay i recieved my jdm foglights for my 94 EG6
does anyone have directions on how to do the install that they can send me?
Thanks
Michael
Thanks
Michael
If they didnt come with any wiring or anything, the easiest way to do it is to go out and get a foglight wiring kit from someplace. It should include everything you need and make the install nice and simple.
Other than that, do a search, im sure this has been covered before.
Confirmed.
Did a search, nothing. I too have JDM fog lights, not even the dealerships have copies of the install because it all came with the kit. They would install and throw away.
On Monday, I'm going to call Honda customer support. They HAVE to have an electronic archive of everything they've produced. I'll ask them to fax me a copy of the install and parts list to make sure I have everything.
By the way, does anyone know how to cut the bumper holes properly? I followed cutout line molded into the bumper, but the casing isn't lining up. I'll post pictures.
here ya go I found this on majestic hondas website under
1999 & Prior Accessory
Installation Instructions
here is a link to the main page http://www.hondaautomotivepart...l.htm
here is a link for the foglights: http://www.hondaautomotivepart....html
I knew i saw this **** somewhere...hope this helps
Instructions found at the above link.....
EDIT: Guy above beat me to it
Did you get the wiring harness and all? You will need to cut the bumper as the Honda instructions say to. The wiring is different though from the USDM and JDM harnesses. There are two wires that go to the fusebox accessories. They are labeled both on the wires and the fusebox. Plug this in. Ground the ground and relay somewhere under the dash. Run one wire connecting the exterior harness to the interior harness. Oh, and ground the exterior harness. That's it. Very simple.
D16 madwoman
Dec 1, 2003 05:35 AM
