Skunk2 Pro 1 vs Rocket M22
Old Jun 11, 2005 | 03:46 AM
red civic standard's Avatar
Default Skunk2 Pro 1 vs Rocket M22
The motor is a a JDM ITR (11:1 CR) with bolt ons. I have an SMSP header and the proper valvetrain to support either of these cams. I have used skunk2 stage 1 cams and buddy club 3+ cams in the past but I am ready to move to some more aggressive cams.
DonF has stated that the pro 1 beat the m22 on his 11.6:1 GSR. The 2 cams were about even on this 11.7:1 2.0 liter:
https://honda-tech.com/zerothread?id=1141681
My biggest concern is with my stock 11:1 compression ratio. Which cams will work best with this compression ratio?
Old Jun 11, 2005 | 05:05 PM
chameleon's Avatar
Default Re: Skunk2 Pro 1 vs Rocket M22 (red civic standard)
i got some pro1s for sale! when u decide hit me up!
Old Jun 11, 2005 | 05:44 PM
ShaunRR's Avatar
HT White Ops
Community Builder
I think you would love either. When you buy the M22's, they come with an ECU chip that works very well in most cases. The Pro1's can be a little tricky to tune.
Old Jun 11, 2005 | 05:48 PM
Rocket's Avatar
Default Re: Skunk2 Pro 1 vs Rocket M22 (chameleon)
If you wanna pull to 9.5k then m22x is really good. Otherwise it's a toss up powerwise from the dyno's I've seen.
Old Jun 11, 2005 | 05:49 PM
Default Re: Skunk2 Pro 1 vs Rocket M22 (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">If you wanna pull to 9.5k then m22x is really good. Otherwise it's a toss up powerwise from the dyno's I've seen.</TD></TR></TABLE>
I will be having them professionally tuned with hondata s100.
Anyone else have an opinion? Do I have enough compression for the Pro 1?
Old Jun 11, 2005 | 05:50 PM
Combustion Contraption's Avatar
What about for 8k and under rocket?
Old Jun 11, 2005 | 05:58 PM
Rocket's Avatar
Default Re: (LsVtec92Hatch)
Our cams are usually sold as a package with a custom chip so one will have less problems with the tune.
Obviously I am biased but there are couple things we do a lil different with the cams that I like over the Skunks.
Old Jun 11, 2005 | 11:48 PM
UncleD's Avatar
Default Re: (Rocket)
I think it boils down to where you want to make your power and how high you want to rev. The M22's have been proven time and time again....bottom line, you CANNOT go wrong with the product, custom service, or the horsepower numbers. Both are an awesome cam, but I personally like the M22....the <U>best</U> money I ever spent on my motor
Old Jun 12, 2005 | 03:36 PM
Default Re: (clean rice)
bump
Old Jun 14, 2005 | 05:36 PM
oldskool teggy's Avatar
Default Re: (red civic standard)
pro-1's have 12.5mm lift and rockets have 12.1mm i like the lower rpm figures of the pro1, but for my setup personally, i dont want to run something with that much lift.
unless you really spec your parts and measure everything, and make sure your valvetrain and handle it.
Old Jun 14, 2005 | 05:46 PM
ChaseIntegra's Avatar
Default Re: (Oldskool teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oldskool teggy &raquo;</TD></TR><TR><TD CLASS="quote">pro-1's have 12.5mm lift and rockets have 12.1mm i like the lower rpm figures of the pro1, but for my setup personally, i dont want to run something with that much lift.
unless you really spec your parts and measure everything, and make sure your valvetrain and handle it. </TD></TR></TABLE>
Agreed. The thing I like is the fact that the M22's will work fine in a GSR with stock compression just meaning the more compression and more mods added, the more potential the cams have to work at the optimum performance.
Old Jun 14, 2005 | 06:39 PM
xDicktonesx's Avatar
hey im so sorry i dont have anythign to add to this but that is the absolute shadiest sleepy sleeper i think ive ever seen as far as a honda goes. maybe throw a baby seat in there. jeeez. good work.
Old Jun 14, 2005 | 06:46 PM
Hybrid96EK's Avatar
Default Re: (CRXofPain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXofPain &raquo;</TD></TR><TR><TD CLASS="quote">hey im so sorry i dont have anythign to add to this but that is the absolute shadiest sleepy sleeper i think ive ever seen as far as a honda goes. maybe throw a baby seat in there. jeeez. good work.</TD></TR></TABLE>
I roll around with my baby seat in the back on my car
To add to the thread, I am running the M22's in my 11.3:1 compression B18C1 and absolutely love the cams. Power gains all the way from ~3,000rpms up.
Old Jun 15, 2005 | 03:27 AM
wolve's Avatar
Default Re: (Hybrid93Eg)
DAMN.....
Love your car. not even a tach, just shiftlight noone can see.
you're a geniusss!!!!
Old Jun 15, 2005 | 04:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
To add to the thread, I am running the M22's in my 11.3:1 compression B18C1 and absolutely love the cams. Power gains all the way from ~3,000rpms up. </TD></TR></TABLE>
How much gains and at what RPM and vs what cams? Dyno chart?
Old Jun 15, 2005 | 07:45 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">
How much gains and at what RPM and vs what cams? Dyno chart?</TD></TR></TABLE>
I have no dynos against other cams at this time. This is a dyno of before and after I fixed piston rings, all other things remained the same...
There is still some tuning left to be done, but its fairly close in that graph. Stock 60mm TB isn't helping me breathe up top.
Old Jun 22, 2005 | 08:19 PM
JBONES's Avatar
Hey rocket! Im trying to decide which cam i should use. Im running a b18c with (12:1 cpr) and need to change cams. Which cam would be better! Yours or the skunk2 pro? Any suggestions would be nice. Sorry if im thread jacking or anything.
Old Jun 22, 2005 | 09:01 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Skunk2 Pro 1 vs Rocket M22 (JBONES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JBONES &raquo;</TD></TR><TR><TD CLASS="quote">Hey rocket! Im trying to decide which cam i should use. Im running a b18c with (12:1 cpr) and need to change cams. Which cam would be better! Yours or the skunk2 pro? Any suggestions would be nice. Sorry if im thread jacking or anything.</TD></TR></TABLE>
At that compression, you might like the M22's better. They will tend to carry more power in the upper rpm ranges than the Pro1's.
Old Jun 23, 2005 | 09:30 AM
Rocket's Avatar
Ask Blundar,
He's really liking the M22's over the other cams he has tuned.
Asking me to about S2 v. RM is like asking David Hsu the same question.
Old Jun 23, 2005 | 09:42 AM
blundar's Avatar
I have a 89x85mm 12.8:1 compression dart block build w/ 50mm ITBs that will be using the Skunk2 Pro1s. I'm not sure if this motor will be a meaningful comparison to plenum manifold stock bore motors, but I'll be sure to post up comments after it's done.
I just got done with a GSR w/ JDM ITR pistons, ported B16 head, flat valves, M22s, skunk2 IM and it was very impressive.
My immediate point of comparison was a GSR w/ JDM P30 pistons and BC3+ cams. There really was no comparison between the two motors, despite compression being roughly equivalent.
Rocket's stuff works. I've heard great things about the Skunk2 Pro1s as well. I'd look at price and availability as determining factors because both are geat cams.
Old Jun 23, 2005 | 12:33 PM
VtecKiDD's Avatar
Default Re: (blundar)
Rocket +1 vote
I have sold tons of Pro1s through my day job, and ive sold tons of Rocket motorsports camshafts as well.
I simply prefer RM, i ran his cams on my old motor, and will be stepping up to some bigger ones for my new motor.
YOU CANNOT BEAT THE POWER, PRICE, PACKAGE deal you get with RM.
Old Jun 23, 2005 | 12:41 PM
zad5's Avatar
does anyone have dyno sheet with buddyclub 3+ vs m22 or skunk2 pro 1. wondering how it compares especially low and mids also when does the buddyclub power start droppin 9k or 8.5ish.
97_Built
Jul 8, 2009 06:42 AM
Egpower88
Feb 14, 2009 07:32 PM
MugenB18cTeC
Jun 11, 2004 09:02 AM
JDMSI
Jan 21, 2003 02:26 PM
