Is my short shifter normal?
Old Jun 11, 2005 | 12:06 AM
gameknb's Avatar
Default Is my short shifter normal?
I have a short shifter in my EM1 and the throws are shorter, but when in neutral, I can move the shifter left and right loosely. Not sure on gears but in neutral I can, is this normal for a SS? Thanks.
Old Jun 11, 2005 | 12:12 AM
niterida's Avatar
Default Re: Is my short shifter normal? (adobopower)
yes you should be able to move the shifter left and right when in nuetral, otherwise you wouldn't be able to move the shifter over to shift gears
Old Jun 11, 2005 | 12:15 AM
gameknb's Avatar
Default Re: Is my short shifter normal? (niterida)
Yes, I know that.. Sorry if you misunderstood but it's very loose, and it moves around alot. Looser then a stock shifter.
Old Jun 11, 2005 | 05:28 AM
sohc_boy's Avatar
did u make sure the shifter is properly seated in it's socket? did u also replace the shifter bushings when u put the short shifter in?
Old Jun 11, 2005 | 06:55 AM
Crasian's Avatar
Default Re: Is my short shifter normal? (sohc_boy)
probbably your shift linkage bushing where your shifter attaches to the linkage, my buddies car did the sanme thing, u could even move it side to side when it was in gear
Old Jun 11, 2005 | 07:30 AM
civiccpedx's Avatar
Default Re: Is my short shifter normal? (FarOutCoupe)
sounds like the linkage wasn't tightened enough, or you need new bushings
Old Jun 11, 2005 | 07:32 AM
solareclipseauto's Avatar
check your bushings
Dm914
Transmission & Drivetrain
Jul 10, 2017 05:05 AM
ProjectCD5
Feb 21, 2006 11:55 PM
mr_wasabi
Jul 12, 2004 03:12 PM
Regular Series
Sep 14, 2002 10:41 AM
SOHC_MShue
Jun 20, 2002 02:44 PM
