Anyone running 30p offset on EF?
Old Jun 10, 2005 | 09:07 PM
whacking stick's Avatar
Default Anyone running 30p offset on EF?
Hi, im going to buy a set of wedsport rims that are 14x6.5 with 30p offset.
Will these fit my ef fine without rubbing?
here's a pic of the wheels - wedsport RS5:
Old Jun 10, 2005 | 09:09 PM
Default Re: Anyone running 30p offset on EF? (EG8T)
Oh, also, what tires would you reccomend?
195/60/14?
or something a little more low profile? do they make a 50 or 55?
Would probably throw out the speedo if i fitted lower profile anyway..
Old Jun 10, 2005 | 09:14 PM
RapeV-8's Avatar
yes it will rub! u may get get away if 35 off set but not 30...
Old Jun 10, 2005 | 09:45 PM
Default Re: (igotcrx)
Really?
how much will they stick out?
Is there anything I can do to stop them rubbing?
Old Jun 13, 2005 | 01:58 PM
RapeV-8's Avatar
well it stick out 1/4 of an inch! the tires will rub unless u sure 195/50/15 and cut ( not roll) the rear wheel well...
Old Jun 13, 2005 | 04:40 PM
SiZ's Avatar
SiZ
They should rub like crazy. I had 38mm offset and they rubbed a quite a bit. It was a major pain in the ***.
As far as 14" tires go, there's 185/55s, but I assume it would be about the exact same height.
Old Jun 13, 2005 | 04:57 PM
nihkon's Avatar
Default Re: (SiZ)
I'm running like 32 or so offset with 205/50/15, and I only rub in very extreme cornering. Stiff suspension helps in this department though.
Old Jun 13, 2005 | 05:12 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotcrx &raquo;</TD></TR><TR><TD CLASS="quote">yes it will rub! u may get get away if 35 off set but not 30... </TD></TR></TABLE>
not true at all...i was looking into 25 offset myself, they wont rub depending on the width of the rim and tire...
talk to 1JDMEF9, he is who i talked to when i was looking for low offset rims...
Old Jun 13, 2005 | 06:39 PM
Targa250R's Avatar
be professional
Default Re: (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
talk to 1JDMEF9, he is who i talked to when i was looking for low offset rims... </TD></TR></TABLE>
I have +25 wheels. 8" wide, 235 tires. They go 1-1.5" past the fender.
Modified by Targa250R at 10:50 PM 6/13/2005
Old Jun 13, 2005 | 06:45 PM
ShiroX's Avatar
ive run 15x6.5 +33 offset with 195/50 Toyo t1s tire and DID NOT rub another 3mm is not going to rub
I did not roll the fender or cut
https://honda-tech.com/zerothread?id=715289 pictures
Old Jun 14, 2005 | 02:39 AM
Default Re: (ShiroX)
Oh well, ive bought them now, just awaiting for them to arrive. il be running 185/60/14 to start with, will let you guys know how I get on.
Thanks for the replies.
Jdm=Ep3
Sep 7, 2009 03:51 PM
GroundZer0 336
Feb 5, 2009 01:31 PM
CWBETB
Apr 19, 2007 04:52 PM
ecovillain
Aug 29, 2005 09:30 AM
SpoonPL
Jan 12, 2002 05:30 PM
