Limp mode 91 civic si ?
Old Jun 10, 2005 | 08:38 PM
civic95hbvtec's Avatar
Default Limp mode 91 civic si ?
where to start ? is what i need to know. First off ill tell ya about the car
it had a B16 dude pulled it out gave me the stock si motor and brand new
uncut harness. I installed it all started it and it went into safe mode. The only
thing not hooked up is the O2 sensor cause i have a 4 wire and need a 1 wire.
That shouldent make it go into limp mode though and i have 2 pm6 ecu's so
they shouldent both be bad. My cluster isint working either only the battery
light. So where do i start to trouble shoot first ? please help !! Im new to this
but have a good basic knowledge and did the swap myself idols great its in time
just hits rev limiter cause of limp mode can you bypass it ? help help help
Old Jun 11, 2005 | 01:05 PM
phatstyles's Avatar
Default Re: Limp mode 91 civic si ? (civic95hbvtec)
on your ecu it should blink if you have any codes running. I would say go get that o2 sensor right away and see what happens.
Old Jun 11, 2005 | 09:39 PM
Thanks for the reply ya the CEL is not on at all no codes and the ECU
is solid red i was reading alot about it sound like it might be the O2 sensor
so im getting one 2morrow and ill try that if its not that im at a lost cause
everything else is hooked up perfect exept im haveing problems with the cluster
THANKS ANY more info is great !!!!!!!!!!!!!!!!!!!!!!!!!!!!! LIMP MODE is Bull Crap !
Oh ya anyway to fool the ECU ? i dont care if its a bad idea its just a d16 there cheap !
sohc_ef2
Sep 29, 2012 05:34 PM
project91crxsi
41
Oct 30, 2009 04:56 PM
EVOCELICA
Mar 9, 2004 07:12 AM
EVOCELICA
Nov 20, 2002 11:44 AM
