taking off rear hub, 1 torx screw stripped!!!!
doing 5lug conversion. in the rear im taking out that fat 24mm bolt + 4 torx screws.
got 3 torx out, last torx screw is starting to strip. I was thinkin about using one of my sockets that are meant for stripped nuts. (the kind that has TEETH to grab on to the sides)
any other ideas? would using a larger torx work?
please!! someone help!!
thank you honda tech!!!!!!!!!!!!
will impact work ALOT better than a breaker bar?
i'll go buy one ASAP, if you think impact will work ALOT better.
i need this thing OFF! asap!
thanks!!
any other tips/ideas?
thanks!!
I've read in general that getting out those torx screws is hard and once you strip it then you need to swap the whole trailing arm...not sure if that's bs but that's what I've heard.
If you can, drill out the screw or get a dremmel and cut it out
If worst comes to worst, you can always drill a small hole in the center of the existing bolt.
Then go to home depot, and get a thing called an EZ-Out, which is pretty much something that you can screw in with a drill or a pair of pliers or something, but you can't unscrew it.
That tool will grip on the bolt from the inside of it, and allow you to unscrew it.
Only drawback is that you need a lot of room to drill that initial hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by easymac »</TD></TR><TR><TD CLASS="quote">
Only drawback is that you need a lot of room to drill that initial hole.</TD></TR></TABLE>
you can drill from the outside of the the car (if arm is still on car) if you take the hub off. Use the easy out asap after drilling the heat will help it break loose.
You're talking about the little screws that hold down the dust shields, right? When I removed the shields, I broke the screws loose by clamping the vice grips on the small lip on the head of the screw (still had to do some cutting to the shields). If you're talking about some screws that the head lays flat with the surface, this obviously wouldn't work (the screws that hold the rotors for instance). For those I have an impact screwdriver. Not compressed air, you literally impact it with a mallet and it turns the screw. Got it at Harbor Freight.
Well.. sounds like you need impact driver. When you turn the driver it wants to back out and start to strip right? Using impact driver(not air tool) when you hit it with the mallet it compresses and turns the screw with the force applied.
yh23
Feb 18, 2007 12:13 PM
roterx7
23
Mar 5, 2006 11:09 AM
