engine cuts off at high rpm..
Old Jun 10, 2005 | 06:09 PM
accordtunerx's Avatar
Default engine cuts off at high rpm..
just had a question for you guys to see if anyone has experienced this before. whenever i'm driving around in a certain gear and hit about 7k (h22), the tach starts getting a BIT jumpy and then all of a sudden it feels like i hit a speed governor or something... the power just shuts off abruptly for a second and the revs drop. there's a loud noise and vibration that i can feel when this happens. so far, its happened in both 3rd and 4th gear. anyone know what the problem might be?
Old Jun 10, 2005 | 07:47 PM
P_Adams's Avatar
Default Re: engine cuts off at high rpm.. (accordtunerx)
Some of the guys that massage ECM's will be more versed than I in this, but I believe You're running up against a programed rev limiter. It's most likely programmed per application (vehicle/engine) specific, so I'd suggest waiting for furthur replies
P
Old Jun 12, 2005 | 11:48 AM
Accord95Lxxx's Avatar
that is sooo a rev limiter
Old Jun 12, 2005 | 08:40 PM
yeah, but i'm running a chipped ECU which has an 7,800 rpm rev limiter... and also this problem doesn't occur in 1st gear or if i'm in neutral revving... so it can't be a rev limiter.
accordtunerx
Jun 14, 2005 08:17 PM
Jeff99Base
May 21, 2005 11:40 AM
MOVE OVER
Mar 12, 2005 02:12 PM
1SlowSi
Feb 25, 2004 05:59 AM
pkprelude
May 8, 2003 04:48 PM
