2 map sensor plugs, which one to use
Old Jun 10, 2005 | 05:49 PM
BoostedEgHatchFl's Avatar
Default 2 map sensor plugs, which one to use
I have a 92 dx hatch back, and I swaped a 95 ex motor and harness into it. The dx had the map plug wired into the car harness down by the battery and the map was on the firewall. The ex has the map on top of the trottle body and the map plu g is wired into the ex engine harness. When I use the ex map and plug the car runs fine but I have a check engine light, and its code number 3. When I use the dx map and plug the check engine light doesn't come on, but the car boggs really bad and idles at like 500-600 rpms. I would like to know when plug and harness do I use.
Old Jun 10, 2005 | 06:42 PM
d357r0y's Avatar
Default Re: 2 map sensor plugs, which one to use (BoostedEgHatchFl)
I suggest you take that chunk of **** car and beat on it with an axe handle for a while.. after you get done with that, take those gayboi 14's and put them in a local sewer cause they are total ****.
Someone help this boy out, he wants to drive his car!
Old Jun 13, 2005 | 05:23 AM
Default Re: 2 map sensor plugs, which one to use (d357r0y)
Thanks JoJo. Come on guyz I need help.
Old Jun 13, 2005 | 07:24 AM
mike1114's Avatar
check both sensors with a multi-meter and see which one is in spec. Things like tps outta spec, dirty IACV and dirty FITV can make these things happen too.
MMMGIRL
Oct 19, 2014 02:44 PM
BoostedEgHatchFl
Feb 19, 2012 07:23 PM
mayfly
Jan 23, 2011 10:54 AM
LS94tegra
Oct 13, 2008 05:17 PM
RudeLude95
Apr 14, 2005 11:30 AM
