95 accord vtec how much transmission oil/fluid?
Old Jun 10, 2005 | 04:51 PM
technine's Avatar
Default 95 accord vtec how much transmission oil/fluid?
I'm gonna be changing out my bros axles tomorrow so I thought it was a good time to change out the tranny fluid as well. How much fluid does the tranny take? It is a 95 sohc vtec accord with a manual transmission. What is a good fluid to use? Should I just go with oil instead? 10-w40? TIA
Old Jun 10, 2005 | 05:28 PM
YeuEmMaiMai's Avatar
Default Re: 95 accord vtec how much transmission oil/fluid? (technine)
Use the Honda oil and I am not sure how much it takes
Old Jun 11, 2005 | 02:06 PM
integ6657's Avatar
Default Re: 95 accord vtec how much transmission oil/fluid? (YeuEmMaiMai)
Use standard 10 w 40 oil and fill it at the bolt in the tranny untill it comes out
Old Jun 11, 2005 | 02:23 PM
NAiL05's Avatar
Use Honda MT Fluid which should be similar to 10W30 or 40 if i remember. There should be a bolt underneath the passenger side axle. Fill that up with the fluid until it leaks out as integ said. Plug it up and then you should be good to go.
Old Jun 13, 2005 | 12:54 PM
technine's Avatar
Default Re:
Thanks everyone. I forgot about that bolt hole, I guess I got use to auto trannies.
Old Jun 13, 2005 | 01:06 PM
Rad Racing's Avatar
Bart Taylor Look-alike
Default Re: Re: (technine)
If you have'nt done it yet, use Honda MTF takes about 2 1/2 quarts, take the speed sensor off and put a funnel down the hole and fill. Better than pumping it in....
Old Jun 13, 2005 | 05:38 PM
technine's Avatar
Default Re: Re: (Rad Racing)
I might do that, but it's probably easier the old way with a tube to the fill hole and a funnel. Done it on my civic and I also did the speedo thing before, but I think it would be easier and faster just doing it with the tube and funnel way. Thanks though.
Old Jun 13, 2005 | 07:19 PM
Rad Racing's Avatar
Yea, if you are just doing the tranny fluid, it is usually easier to do it through the real plug.
916B18c1
Jun 30, 2008 04:22 AM
St3v3
Apr 22, 2007 04:03 PM
Tokyo_X-treme_Racer
15
Jul 21, 2004 12:48 PM
92civiclx
Jun 30, 2003 01:00 AM
Ignitecivic
Apr 3, 2002 01:13 PM
