Car not starting ...please help
Old Jun 10, 2005 | 03:22 PM
blacksihatch's Avatar
Default Car not starting ...please help
I just put my B16 put back together and when I attempt to start it it just turns and turns and turns ...why wont it firer up??
Old Jun 10, 2005 | 03:38 PM
philafelman's Avatar
Default Re: Car not starting ...please help (blacksihatch)
possibly flooded? check the spark plugs-also check your ecu fuse.
Old Jun 10, 2005 | 03:41 PM
Default Re: Car not starting ...please help (philafelman)
how would i un-flood it and the ecu fuse is good
Old Jun 10, 2005 | 04:05 PM
you can flood it crankin it over and over. try holdin the throttle wide open when you start it.
Old Jun 10, 2005 | 04:09 PM
any other suggestions?????
Old Jun 11, 2005 | 02:29 AM
327da9's Avatar
Do you even have spark or fuel pressure when your cranking the car?
Old Jun 11, 2005 | 10:05 AM
DSRxMilogen's Avatar
Default Re: Car not starting ...please help (327da9)
firing order?... seems stupid... but it happens
Old Jun 11, 2005 | 10:11 AM
Tmack's Avatar
cams in backwards? you said you just put it back together right? how apart was the motor?
Old Jun 11, 2005 | 02:52 PM
Default Re: (Tmack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tmack &raquo;</TD></TR><TR><TD CLASS="quote">cams in backwards? you said you just put it back together right? how apart was the motor?</TD></TR></TABLE>
if the cams were backwards, i dont think theres any way in hell you could get the distributor on.
Old Jun 11, 2005 | 06:18 PM
RedEj8's Avatar
Default Re: (philafelman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">
if the cams were backwards, i dont think theres any way in hell you could get the distributor on.</TD></TR></TABLE>
Nope
A guy i know just put his motor in his car and it did the same thing.Turned out to be a bad distributor.
Old Jun 11, 2005 | 07:03 PM
itralex's Avatar
Default Re: (reddohcvtec)
valve lash incorrect?
Old Jun 11, 2005 | 10:50 PM
i dont you can get your cams are in backwards.. how would you even put in your dizzy if that were to happen.. there's no slot on an exhaust cam...all you need is spark, compression, timing, fuel......
1) ground your plugs to see if you have spark..
2) check if your timing belt and all that are on correct...
then if that all checks out..
3) then turn your key to the on position, take out your dizzy and ground it to the block. slowly start turning the fork part that slips into the slot on the intake cam with your fingers and you should hear clicks from each injector....that means they are working...
if that checks out, then check your compression...
sorry if you get confused.. i'm in a rush.. but if you have any problems with anything i explained then PM me
Old Jun 11, 2005 | 11:02 PM
b19coupe's Avatar
Check the ground by the thermostat housing. Distributor plugged in, and check all of your connectors. Things like this usually turn out to be something simple.
Old Jun 13, 2005 | 04:12 PM
Tmack's Avatar
by backwards I meant 180 degrees off, not intake in the exhuast etc. lol.
Old Aug 11, 2005 | 11:10 PM
90AcuraIntegra04's Avatar
My firebird had the same problems when i put a carb. on it. I ended up flooding it and it would not start. Take out the sparkplugs, see if they are wet and smell like gas, if they do, get new ones and it should start right up!
shawn_090
Jun 24, 2008 01:03 PM
duhafnusa4
Mar 19, 2008 05:35 PM
BALLIN H22 EK
Feb 24, 2006 12:36 PM
sohc90rex
16
Dec 21, 2005 09:20 PM
96integraLS
Oct 30, 2004 05:23 PM
