car flutters until warmed up
when i start my car, and start driving it makes this kwazi tick-ish fluterry sound.it does this till ive gone up the street a couple miles then it goes away,but if my car is off for a couple minutes then itll do it again.
is it valves(something repairable?)or something else i need to have replaced/adjusted
i keep the oil changed before its due or the exact time,so my oil shouldnt be affecting it should it?
is it like a constant "ehzhzhzhzhzhhhh" noise thats kind of like a grinding noise where the timing belt is? because mine is going the same, and its only when not warmed up. and after i start the ignition and the rpms go up, it starts the noise about 3 seconds after its running, so its a delayed noise at first.
its an hx(not too much longer) so its vtec-e,so how do i go about trying this out to see if it solves my problem?
the sound would sound like a tick at first when you hear it but its not like what the inside of a warch would sound like,it has the weird.....like i said fluttery sound
jovial111
May 7, 2003 12:36 PM
