crx ls swap
im new to this site and tis is my first post so any help will be highly appreciated i have found a 90 crx and if i buy it i will be swapping a b18 or b20 and keeping it obd0 what wiring mods will i have to do i think i got the mechanical part but the wiring is a mysterie thanks for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90b20b4 »</TD></TR><TR><TD CLASS="quote"> i think i got the mechanical part but the wiring is a mysterie thanks for any help</TD></TR></TABLE>
Keeping it obd0, use a 90-91 integra distributor, pr4 ecu, obd0 injectors, all plug and play. If you have the dx, a multiport conversion is in order. A search on this site can reveal a lot.
HTH
chris
HTH
chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris »</TD></TR><TR><TD CLASS="quote">Keeping it obd0, use a 90-91 integra distributor, pr4 ecu, obd0 injectors, all plug and play. If you have the dx, a multiport conversion is in order. A search on this site can reveal a lot.
HTH
chris</TD></TR></TABLE>
Search
HTH
Search
If you get a 1990 CRX si or HF, your wiring is done. MPFI integras were the same as MPFI CRX's. So there is no wiring
If you end up with a DPFI CRX DX, checkout http://www.rywire.com. You'll need the MPFI swap "dx to si"
im gonna be running a b18a out of a a 90 91 integra and ill have the ecu and all the wiring and thanks alot guys and i think i have found my second home here at h-t peace
hondacrx97
Nov 27, 2007 06:48 AM
