lsvtec cams
i finally made up my mind i have decided to go with this lsvtec set up:
1. CTR pistons
2. Piston rings
3. New OEM HONDA Bearings
4. Bottom end gasket kit
5. New OEM HONDA Oil pump
6. Bore, hone, step decked, resurfaced,
and hot tank block and R&R rods
now i just need to know wut cams to put in. wut would u suggest is good for this setup? i was thinking about buddy club or itr/ctr cams. any other opinions?
and i am running p28 ecu plan on getting hondata s100 and getting rmf headers.
1. CTR pistons
2. Piston rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">May I suggest having the engine balanced as well.</TD></TR></TABLE>
ARP rod studs would be a great investment as well, if you don't already have them... Is that a GSR/ITR oil pump you're running?
known
Jun 12, 2006 03:49 PM
