radio/cigarette lighter fuse keeps blowing
Old Jun 10, 2005 | 09:42 AM
HedgeCore's Avatar
Default radio/cigarette lighter fuse keeps blowing
my friend just got an amp and sub installed "professionally," and he said that after a day or so his deck wouldn't come on when he started his car. he took it in to the place where they installed it, and they fixed, but he had the same problem again a few days later. i checked out his car and determined that the fuse for the radio/cigarette lighter was blown, and replaced it. as soon as he started his car after this, i saw a spark/flash from the fusebox, and the same fuse (the new one) was blown again. so what would cause this? is there too much power coming through somehow? any ideas?
Old Jun 10, 2005 | 12:01 PM
fcm's Avatar
fcm
Old Fart
Default Re: radio/cigarette lighter fuse keeps blowing (HedgeCore)
You need to know what is blowing the fuse, the lighter ot the HU, I would try unplugging the lighter, [at the back] and see what happens, if the fuse blows so fast that it "spark/flashs" it sounds like a bad short, if after unplugging the lighter you still have the problem, then it's time to pull the HU and see what kind of wiring job the place that did the install has done, a common problem on Honda/Acura HU installs is the wire harness, or part of it, will get "pinched" under the back of the HU, and after a short time the wires will short out. 94
bwr93 civic
Nov 12, 2015 10:15 AM
loki2323
Audio / Security / Video
Jul 22, 2015 05:48 AM
eg grom
13
Oct 22, 2009 09:44 PM
Sic_DA_Nine
Jan 8, 2007 09:54 AM
