ANOTHER axle question
Well, is it for the 4 lug or 5 lug? Since there is no 4 lug DC, I am assuming it's the 5 lug...
The 04/05 EP3 5 lug fit the DC5 chassis. Yes.
The only difference, is I think that the EP3 axles are a bit shorter... and these drive shaft shop axles are the EP3 length, because some DC5 people had problems for some reason with the differential seal because it's shorter? dunno
You shouldn' have any problems with the DC axles if you are 5 lug, but if you are 4 lug I thought they were different spline patterns, 35 vs. 32 or something...
Gimmie a few weeks and I coulda given you pics
eg/dc as in DC2 id imagine just because the eg6/dc2 hav similar front ends and i dont think those driveshaft shop axles will work because on the older generation civic and integras, the transmission is on the complete other side of the car unless u just reverse the passenger axle with the driver side axle.........but i would call the person u ordered them from and or the company that makes the axles.
