what cams can i use WITHOUT after market valve train??
Old Jun 9, 2005 | 10:55 PM
asocallocal's Avatar
Default what cams can i use WITHOUT after market valve train??
please give me a list. i need something powerful but at the same time i dont want to upgrade the valvetrain. ( i got ctr cams already so no OEM cams)
jun2
skunk2
buddyclub
rockets
crower
crane
its going into a b16a with ctr pistons. thanks for looking and thanks to all the helper in advance
Old Jun 9, 2005 | 11:19 PM
Default Re: what cams can i use WITHOUT after market valve train?? (asocallocal)
whats the biggest cams i can run with this setup with valvetrain
AND
whats the biggest cams i can run with this setup WITHOUT valvetrain.
i just scare of valve clearence, let me know whats up
Old Jun 9, 2005 | 11:36 PM
5STAR3's Avatar
why be cheap?
is it worth it? good valvetrain is $250.
Old Jun 9, 2005 | 11:41 PM
i dont want to upgrade when i dont need to.
i think ill be able to run some cams with out it, but just cant rev like crazy. ill probably shift at 8200 to be safe
where can i get cheap but good vavletrain, portflow?
Old Jun 10, 2005 | 12:06 AM
turboJDMeg6's Avatar
me i would think any stage one cams would be fine..or just up ur valvetrain to itr's n run s2s2 cams
Old Jun 10, 2005 | 09:01 AM
si2kcivic's Avatar
Default Re: what cams can i use WITHOUT after market valve train?? (91b16ef9)
is it safe to rev to 8200 with S2S1 and no valve train upgrade?
Old Jun 10, 2005 | 09:20 AM
97L-esVeeTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91b16ef9 &raquo;</TD></TR><TR><TD CLASS="quote">me i would think any stage one cams would be fine..or just up ur valvetrain to itr's n run s2s2 cams</TD></TR></TABLE>
s2s2 cams have 12.3mm of lift on the intake and 11.8 on exhaust, do not run itr valvetrain with those cams, spend 250 bucks on a valvetrain if you wanna run anything more aggressive than your avg. stage 1 cam, even then you would want err on the side of safety and upgrade if plan to rev higher than stock rev limit
Old Jun 10, 2005 | 09:25 AM
Viorent Grip! EG's Avatar
Default Re: what cams can i use WITHOUT after market valve train?? (97L-esVeeTeg)
i would say a ctr/itr set up....makes good power too....with oem valvetrain
Old Jun 10, 2005 | 11:42 AM
Rocket's Avatar
Default Re: what cams can i use WITHOUT after market valve train?? (Viorent Grip! EG)
None.
Old Jun 10, 2005 | 01:48 PM
NA-DB8's Avatar
Default Re: what cams can i use WITHOUT after market valve train?? (Rocket)
IT'S WORTH GETTING VALVE VALVE TRAIN. BUT IF YOU DONT WANT TO GO THAT ROUTE THEN YOU SHOULD USE SKUNK2 STAGE 1 CAMS OR THE BLOX TYPE A CAMS....
Old Jun 10, 2005 | 06:28 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">None.</TD></TR></TABLE>
Old Jun 10, 2005 | 06:46 PM
dc-lefty's Avatar
Default Re: what cams can i use WITHOUT after market valve train?? (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">None.</TD></TR></TABLE> best response ever !
Old Jun 10, 2005 | 07:58 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: what cams can i use WITHOUT after market valve train?? (dc-lefty)
I'd go with GSRs on Si valvetrain, and ITRs on GSR valvetrain.
A good valvetrain is worth it.
Old Jun 11, 2005 | 12:17 AM
Default Re: what cams can i use WITHOUT after market valve train?? (LSVTEC 91 Civic)
what will be a okay mix and match combination? ill lists cams and u list a cheap valvetrain for it.
skunk2 stg2= plowflow? itr?
skunk2 stg3=
jun2=
jun3=
m22=
buddyclub=
i want to spend about 150 on valve train and alot on cams
Old Jun 11, 2005 | 12:49 AM
LsVTeCTuRBo17's Avatar
you need the valve train before the cams. why risk dropping a valve spend the money
Old Jun 11, 2005 | 06:51 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal &raquo;</TD></TR><TR><TD CLASS="quote">i dont want to upgrade when i dont need to.
where can i get cheap but good vavletrain, portflow?</TD></TR></TABLE>
its your car do whatever you want. but why would you ask for help and then not take the advise.
dont ask a question if you already have your mind made up.
<FONT SIZE="4"><FONT COLOR="purple">CHEAP AND ENGINE BUILDING DONT GO IN THE SAME SENTENCE</FONT></FONT>
Old Jun 11, 2005 | 08:47 PM
Default Re: what cams can i use WITHOUT after market valve train?? (5STAR3)
[QUOTE=5STAR3]
I DONT HAVE A SET UP IN MIND. I JUST NEED ONE THAT WILL BE WELL ROUNDED TO MY BE A PERMANENT VALVETRAIN BUT STILL UPGRADE CAMS. WHAT WILL BE ABLE TO DO THAT? NO ONE SUGGESTED ME TO GET A CERTAIN BRAND OF VALVETRAIN AND THATS WHAT I NEED.
Old Jun 11, 2005 | 09:48 PM
RedEj8's Avatar
Rocket Motorsports Gen2 Springs and retainers would be good
Old Jun 11, 2005 | 09:57 PM
SPOON_FED_DC_2's Avatar
SENTENCE
</FONT></FONT>[/QUOTE]
Like everyone said spend the extra money and get valve train and run what ever cams you want if money is an issue jus save up.
Old Jun 12, 2005 | 11:44 AM
Default Re: what cams can i use WITHOUT after market valve train?? (SPOON_FED_DC_2)
i just thought that all the valve train works the same therefore i thought why spend a lot just for a brand name when u can get another with the same specs for cheaper.
ill i got an offer for portflow inner spring and itr outter with ti retainer for 200 used. is that a good deal? will these be able to run skunk2 stg2-3 or jun2or3??
Old Jun 12, 2005 | 12:15 PM
Slain's Avatar
you may want to do alot more homework before you go out and spend your money
Old Jun 12, 2005 | 09:43 PM
Default Re: (Slain)
thats what i am trying to do BUT barely anyone is helping me.
At first i didnt want to buy any valvetrain, but now i guess its a must! help me find a vavletrain that will be capable of run different kinds of cams.
Old Jun 12, 2005 | 10:05 PM
teler86's Avatar
Default Re: (asocallocal)
i too am interested in what kind of valvetrain will be suitable for skunk2 stage 2 cams
Old Jun 12, 2005 | 10:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal &raquo;</TD></TR><TR><TD CLASS="quote">thats what i am trying to do BUT barely anyone is helping me.
At first i didnt want to buy any valvetrain, but now i guess its a must! help me find a vavletrain that will be capable of run different kinds of cams. </TD></TR></TABLE>
All i can say is that ive never heard ONE bad thing about omnpowers or Rockets valvetrain. Ill leave it at that.
Old Jun 12, 2005 | 10:53 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asocallocal &raquo;</TD></TR><TR><TD CLASS="quote">thats what i am trying to do BUT barely anyone is helping me. </TD></TR></TABLE>
everyone is trying to help you..its just not safe to run high lift cams on stock valvetrain...at least change the valve springs if u dont wanna redo the whole valvetrain..
also if ur b16 is a 1st gen..then u need to swap out the lmas to either gsr/itr/prelude with a shim...the first gen lma's were not made with a large enough tip for high lift cams...
i know u wanna build a fast motor for cheap but..NA is expensive get used to it
