Battery is dying slowly!
Old Jun 9, 2005 | 10:32 PM
4runner's Avatar
Default Battery is dying slowly!
*i know i had this in the EG forum(accident)*
I think i might know what the diagnosis is but i just wanna make sure....
ok so the wiring harness is fucked for the deck cuz one of the wires (red one) doesnt work. The red wire is the ignition wire so when i put the key in and turn it, it sends power to the radio...Well anywho, that wire is busted so i was force to ***** rig the ignition wire from the deck to the constant power, meaning i can turn on the deck anytime without puttin in the key...I'm not 100% sure whether this is bad or not. Maybe i should wire it to a fuse down by the fuses underneath the steering wheel
could be the alternator
any inputs?
Old Jun 9, 2005 | 10:46 PM
4runner's Avatar
Default Re: Battery is dying slowly! (88HaveFun)
OMFG i think i found the problem, my deck's constant wire is loose and i left it there, it was probably hittin the chasis and the constant wire is unfused!
Old Jun 9, 2005 | 11:38 PM
Burlyirishdude's Avatar
bam boy......You might have found it. fix it and if battery life is sustained then you fixed it. good job homeslice. l8z
TORTUGA
14
Dec 17, 2012 03:57 PM
4runner
Jun 10, 2005 03:36 AM
Tad
Audio / Security / Video
Nov 29, 2003 12:10 AM
BodyKits NW
Aug 9, 2003 12:38 PM
