EK swap question
I just bought a complete B18B bottom end and plan on buying a complete GSR head soon..i know i will have to buy the GSR ECU, shift linkage(will this have to be for a B18 going in to an EK or can it just be a GSR Linkage?)but what else will i need to buy for the swap thats going into my EK? thanks
depends on what tranny youre running, ls tranny use the ls, gsr tranny use the gsr, need conversion harness from firewall to ecu, depending if youre going obd 1 or 2.. everything is plug and play...need vtec oil line..
well, im using the GSR tranny..and im keeping it obd-II so would i still need the conversion?or just the regular wiring harness?anything else that i would need axles etc.?
Check the link in my sig for info.
And there is no reason you can't run a GS-R tranny on an LS engine. There is also no conversion harness from the firewall since OBD2 uses a 1-piece harness design.
want2drive
Jun 14, 2011 10:11 AM
BoOsTiN Dc2
12
Jun 3, 2005 11:50 AM
