What is difference between d15b1 and d15b2 ????
Old Jun 9, 2005 | 06:32 PM
turboEFboy's Avatar
Default What is difference between d15b1 and d15b2 ????
Both engines seem the same to me, so enlighten me. The d15b7 I think is from 92-95 correct? But I just dont know what the difference is between the d15b1 and b2 is from 88-91 years.
Old Jun 9, 2005 | 06:56 PM
MENACE's Avatar
Default Re: What is difference between d15b1 and d15b2 ???? (turboEFboy)
The Throtle bodies are the big difference, the top Butterfly, opens 1/2 way on the b1, Also the spacer plate, bettween the manifold and throtle body has a smaller diameter, on the b1. So basically there identical except the B1 let less air in. I had pics back in the day, befor i finally converted to Mpfi and realized DPFI was garbage lol.
Old Jun 9, 2005 | 07:07 PM
turboEFboy's Avatar
Default Re: What is difference between d15b1 and d15b2 ???? (MENACE)
Cool, thanks for the info, Menace! I for the life of me couldnt see a difference in them. But I threw away the DPFI, so no wonder! I did an Si conversion on my friends DX with the b2 motor. Its strange, but the d15 I did the si conversion on actually runs better and is faster than my d16! Must be the lower rotating mass of the d15 (?)
Old Jun 9, 2005 | 08:51 PM
bagpipe goatee's Avatar
the camshaft is also different between the motors, but both will take the si cam
Old Jun 9, 2005 | 10:14 PM
FOMULA91's Avatar
Default Re: (bagpipe goatee)
D15B1 1.5 8V SOHC PGM-FI 1493 70hp@5500rpm 83tq@3000rpm 88-?? Civic
D15B2 1.5 16VSOHC PGM-FI 1493 92hp@6000rpm 89tq@4500rpm 88-91 Civic DX/LX
Old Jun 9, 2005 | 11:12 PM
Dent Free's Avatar
Default Re: (FOMULA91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote"> D15B1 1.5 8V SOHC PGM-FI 1493 70hp@5500rpm 83tq@3000rpm 88-?? Civic
D15B2 1.5 16VSOHC PGM-FI 1493 92hp@6000rpm 89tq@4500rpm 88-91 Civic DX/LX </TD></TR></TABLE>
Wrong . . .
I have a 88 hatch with a D15B1 and it has 16 valves and it does run better than everyone elses D16a6's That I have met and raced.
I have :
- Si Cam
- Si Trans
- Si ECU
- Si Intake Manifold
- Si Stock Header with internal porting
- Shifter Buchings
- H&R Springs
- No cat w/ stock muffler
Old Jun 9, 2005 | 11:16 PM
93formula's Avatar
Default Re: (Dent Free)
wasnt the 8 valve the cx model and the 16 valve the dx model? which model is yours?
Old Jun 9, 2005 | 11:22 PM
Mach69's Avatar
Default Re: (93formula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">wasnt the 8 valve the cx model and the 16 valve the dx model? which model is yours?</TD></TR></TABLE>
Not exactly. The 8 valve model was the CRX Hf, the d15b6. The d15b1 and d15b2 are 16 valve. The d15b1 was in the STD civic (88-89?) and the d15b2 was in the dx (88-91, certain on that).
Old Jun 10, 2005 | 11:42 AM
Dent Free's Avatar
Default Re: (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">Not exactly. The 8 valve model was the CRX Hf, the d15b6. The d15b1 and d15b2 are 16 valve. The d15b1 was in the STD civic (88-89?) and the d15b2 was in the dx (88-91, certain on that).</TD></TR></TABLE>
Correct
Mine is a 88 STD d15b1 with 175,387 miles and Comp. at 169, 171, 173, 170 &lt;------ Amazing I know . . . All with in 3% - 4%
hfrex
Jan 5, 2009 10:24 AM
b_jonston
Apr 19, 2007 06:14 PM
civicracer1993
May 17, 2003 07:37 AM
Crxer
28
Dec 20, 2002 08:43 PM
Iceycrx
Mar 14, 2002 05:44 AM
