code 15
You're going to have to fix the cause of the check engine light. Code 15 is for the ignition output signal. Check all your wiring, if everything is ok, suspect the ignitor. Does the car run? Does the tach jump?
the car run its my every day driver the tach dusnt jump but if im at a stop and i tap the gas it will bog and then rev higher then idle. the bog is hardcorebut if i tap it like 2 times it will not bog that bad. o ya the bog happens cold or hot.
xwhitchx
Jan 7, 2012 03:41 PM
*Boostwerks*
Dec 24, 2004 10:10 AM
