*HELP* radiator drain plug problem *HELP*
I'm a Jackass
my radiator drain plug is not going on! i just got a new one and it still doesnt fit.. its the one specifically made for my car too so i dont understand why it's not fitting.. somebody help! what do i do? coolant leaks bad.
Put it into the opening, turn it like you are taking it out. It should pop in a tiny bit, then turn it to tighten. Are you sure the plug is perfectly straight with the hole?
Goodluck man.
Goodluck man.
I'm a Jackass
i think their might be a crack..
for now i goobed that hole with some rubber sealant which should hold up for awhile..
any suggestions for a good new radiator???? koyo? fluidyne? etc...???
marauder228vw
Jan 10, 2012 04:27 PM
tercelrcr
Jan 8, 2012 02:35 PM
vti444
Aug 5, 2007 05:22 AM
