1990 CRX SI NO SPARK, NO POWER TO ECU, NO POWER TO FUEL PUMP
Old Jun 9, 2005 | 04:58 PM
TX1RACING's Avatar
Default 1990 CRX SI NO SPARK, NO POWER TO ECU, NO POWER TO FUEL PUMP
I have a 1990 CRX shut down on me on the road, there is no power to the fuel pump, there is no spark, and there is no power to the ECU would anybody know what the problem is?
Old Jun 9, 2005 | 05:08 PM
Chiovnidca's Avatar
Default Re: 1990 CRX SI NO SPARK, NO POWER TO ECU, NO POWER TO FUEL PUMP (TX1RACING)
Fuse?
Old Jun 9, 2005 | 05:10 PM
Mach69's Avatar
Try ur main relay. Mine just took a crap on me too, a lot of ours have.
Old Jun 9, 2005 | 05:26 PM
Chiovnidca's Avatar
Default Re: 1990 CRX SI NO SPARK, NO POWER TO ECU, NO POWER TO FUEL PUMP (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">Try ur main relay. Mine just took a crap on me too, a lot of ours have.</TD></TR></TABLE>
It's very rare for a main relay to cause a stalling problem.
Old Jun 9, 2005 | 06:30 PM
NikoZai's Avatar
Default Re: 1990 CRX SI NO SPARK, NO POWER TO ECU, NO POWER TO FUEL PUMP (Chiovnidca)
I'll pick, the battery!
Old Jun 9, 2005 | 06:43 PM
mr. carpenter's Avatar
Default Re: 1990 CRX SI NO SPARK, NO POWER TO ECU, NO POWER TO FUEL PUMP (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">I'll pick, the battery!</TD></TR></TABLE>
i second that pick
Old Jun 9, 2005 | 06:49 PM
DohcVtecCrx's Avatar
Default Re: 1990 CRX SI NO SPARK, NO POWER TO ECU, NO POWER TO FUEL PUMP (mr. carpenter)
well if all that checks out (the car will drive fine with the battery totally dead, I know I got my beater 4 door home in a long trip and the battery was ****. Turn it off and you wouldn't even get a dome light) check the ground on your thermostat housing and the alt fuse under the dash.
Old Jun 9, 2005 | 09:13 PM
PURPLETERROR aka BIGMATT's Avatar
Alternator fuse under the dash, main relay, or main power fuse under the hood
Old Jun 10, 2005 | 08:26 AM
ALLMOTORCRX20's Avatar
The battery probably ran down on volts. The alternator might not be charging the battery. You might wanna check your charging system.
Old Jun 10, 2005 | 10:40 AM
solareclipseauto's Avatar
Default Re: 1990 CRX SI NO SPARK, NO POWER TO ECU, NO POWER TO FUEL PUMP (ALLMOTORCRX20)
jump it and if you can get it to run unplug the terminal on the battery and see if the battery light turns on, if so your altenator is shot
Old Jun 17, 2005 | 02:16 PM
TX1RACING's Avatar
Altenator fuse was blown
Thanks Alot Guys
Old Jun 17, 2005 | 02:53 PM
gutted-dx's Avatar
Damn it my car is doing the same thing, but it's not the alterneator fuse
Mattb16teg
Jul 8, 2024 07:24 AM
Jamesb223
Jan 21, 2018 08:01 PM
jdmcoupe28
12
Feb 15, 2005 07:40 PM
albert9170
Jan 18, 2005 12:10 PM
