Suspension & Brakes Theory, alignment, spring rates....
ABS code help?
Old Jun 9, 2005 | 04:25 PM
Touge Tuning's Avatar
Default ABS code help?
k i just finished a b18b1 swap on my EK coupe and im getting a ton of ABS codes. Some of them from the rear and i havent even touched the rear brakes.
So here are the codes im getting.
-right rear wheel sensor (open/short to body ground or short to power
-right rear wheel sensor (electrical noise or intermittent interruption.
-left rear wheel sensor (electrical noise or intermittent interruption
-right front inlet solenoid
-right front outlet solenoid
-left front inlet solenoid
-left front outlet solenoid
-right rear inlet solenoid
-right rear outlet solenoid
-left rear inlet solenoid
-left rear outlet solenoid
-fail safe relay
-low ignition voltage
anyone have an idea why im getting all these codes? I didnt even touch the rear of the car.
Old Jun 9, 2005 | 07:53 PM
B20TDC2's Avatar
Default Re: ABS code help? (scarlemthug)
could be in your harness check all of your wiring. you could have disrupted something during the swap
Old Jun 9, 2005 | 08:24 PM
im thinking maybe the ground wire is in the wrong place or something cause i never touched the rear end of the car and all i did was clean up the engine bay wiring by tucking it a bit etc etc.
Old Jun 10, 2005 | 09:49 AM
ttt
John Broecher
Honda CR-V & Element
Apr 18, 2017 09:58 PM
sparkylawdog
Mar 26, 2014 08:53 AM
sTEGasaurus
Jan 28, 2010 08:41 PM
Mikey
Jan 19, 2005 05:39 AM
moepeppa
Sep 15, 2003 03:22 PM
