HAS ANYONE RAN THIS SET UP BEFORE?
Old Jun 9, 2005 | 02:45 PM
JDM KING's Avatar
Default HAS ANYONE RAN THIS SET UP BEFORE?
Hey hows it going everyone, I know the CTR piston in a GSR topic has been covevered but heres another question that isnt covered. Most of you are going to say that I should just clay the motor, in which I might just do but I want a little feedback.
WILL THIS CLEAR? :
-CTR .25 over pistons
-GSR BLOCK
-GSR HEAD
-SKUNK2 stage 3 cams
-OEM 3 ply headgasket
-slight "skimmed kiss" on surface of the head (cleaning)
many say yes it will clear but I just need some feedback...preferable from ones who have this set up already. thanks guys....
Old Jun 9, 2005 | 02:56 PM
JDM KING's Avatar
Default Re: HAS ANYONE RAN THIS SET UP BEFORE? (JDM KING)
ttt? no one knows or no one has this set up?
Old Jun 9, 2005 | 03:00 PM
cpforyou's Avatar
better to be safe than sorry....clay the thing...
Old Jun 9, 2005 | 03:08 PM
JDM KING's Avatar
Default Re: HAS ANYONE RAN THIS SET UP BEFORE? (cpforyou)
indeed thats what i will do anyways, just incase but kinda wanted opinions. theres a 0.40 clearence i heard for the pistons however i guess i should just clay the thing!
Old Jun 9, 2005 | 03:14 PM
HondaIntegraR's Avatar
don't know how the lobes compare, but i had a similar setup w/ crower stage 3 cams... dunno if its from rod stretch or what not, but i had piston to head contact.... the " in" and the arrow on the pct pistons were indented into the head.... dunno if this info is relevant for you but just letting you know....keep in mind that this setup was driven for nearly 3 years, and ran great the first 2 years....
Old Jun 9, 2005 | 03:22 PM
JDM KING's Avatar
Default Re: HAS ANYONE RAN THIS SET UP BEFORE? (HondaIntegraR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaIntegraR &raquo;</TD></TR><TR><TD CLASS="quote">don't know how the lobes compare, but i had a similar setup w/ crower stage 3 cams... dunno if its from rod stretch or what not, but i had piston to head contact.... the " in" and the arrow on the pct pistons were indented into the head.... dunno if this info is relevant for you but just letting you know....keep in mind that this setup was driven for nearly 3 years, and ran great the first 2 years.... </TD></TR></TABLE>
Wow, interesting, so im taking it that your valves bent becuase the "in" symbol is on the flatter portion of the pistons?
skunk2 stage3
IN. 0.504, 270
EX. 0.465, 279
crower stage3
Int- 263 mid
Exh-255 mid
lift:
Int- 468 mid
Exh-468 mid
if im not mistaking the skunks are "bigger"
Old Jun 9, 2005 | 05:07 PM
Yambor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM KING &raquo;</TD></TR><TR><TD CLASS="quote">
skunk2 stage3
IN. 0.504, 270
EX. 0.465, 279
crower stage3
Int- 263 mid
Exh-255 mid
lift:
Int- 468 mid
Exh-468 mid
if im not mistaking the skunks are "bigger" </TD></TR></TABLE>
You've failed to notice something grasshopper!
Crower Measures their cam specs @.050 and Skunk2 measures @ 1mm.
therefore you have to convert crower's specs to mm.
-Skunk2 Stage III -
INTAKE lift- 12.8 mm, duration 270 @ 1mm
EXHAUST lift - 11.8 mm, duration 279 @ 1mm
Crower Stage III's
- 63403
INTAKE lift - 11.98 mm, duration 246 @1mm
EXHAUST lift - 11.83 mm, duration 238 @1mm
Your were right that the skunks are bigger, yet they are bigger than what you thought!
Old Jun 9, 2005 | 06:43 PM
1750cc's Avatar
Default Re: HAS ANYONE RAN THIS SET UP BEFORE? (JH4DC4-2GSR)
arent your cams too big for your motor?
Old Jun 10, 2005 | 06:35 AM
CHEETAH's Avatar
you'll be fine with those cams ... if cleanup is 5 thou or under. the CTR pistons have good valve reliefs.
Greg
Old Jun 10, 2005 | 09:35 AM
JDM KING's Avatar
Default Re: HAS ANYONE RAN THIS SET UP BEFORE? (CHEETAH)
thanks guys for your in-put. The stage3's are pretty large and the head was barely "kissed" so its for sure under 5thou the stage3's are great cams in my opinion,
Modified by JDM KING at 10:49 AM 6/10/2005
Beans90crx
May 21, 2010 07:41 AM
804tuned
Feb 6, 2010 10:30 PM
95dc2
Sep 15, 2004 11:55 AM
devoxtekxhb
Oct 4, 2002 06:22 AM
stretracr
Jun 26, 2001 06:16 PM
