seized Ground Control
Old Jun 9, 2005 | 02:15 PM
EL'ation's Avatar
Default seized Ground Control
I haven't touched it since I installed it cocuple years ago and tried to loosen the screw today and I ended up stripping it.
How do I loose the screw and raise the plate?
Old Jun 9, 2005 | 02:19 PM
blackstar's Avatar
war all of the time......
Default Re: seized Ground Control (EL'ation)
i had the same problem on a set of GC's, luckily they werent on the car at the time. i took a hack saw and carefully cut the bolt, dont scar the sleeve though, but the spring perch will be useless. u can call ground control and order the gold spring perch for $18 plus s/h, and they'll prob toss in the bolt for u
if i was u, i'd go ahead and order the perch and bolt, then take the strut assembly out when the package gets there.
Old Jun 10, 2005 | 05:05 AM
civichatch95md's Avatar
soak it in wd40?
US PB blaster (think thats the name)
Liquid wrench
Any of those is small amounts might help you break it loose.
As for the stripped <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackstar &raquo;</TD></TR><TR><TD CLASS="quote">a hack saw and carefully cut the bolt</TD></TR></TABLE>
And next time dont monkey arm it.
teddy_dc2
Suspension & Brakes
Mar 16, 2011 08:51 AM
Xathine
Suspension & Brakes
Nov 6, 2008 12:51 PM
super_nguyen
Suspension & Brakes
May 30, 2006 02:02 PM
slowr6
Suspension & Brakes
Jan 27, 2005 05:12 AM
5spdIntegra
Sep 17, 2004 02:23 PM
