Sound deadening
Old Jun 9, 2005 | 01:44 PM
SloCrxDx91's Avatar
Default Sound deadening
I have a Crossfire db15 with a legacy 2400 watt 2 channel amp and thing rattles pretty good. I do not want to put the money into buying Dynamat or any other high priced sound deadening material. I was wondering if anyone has any ideas on how to stop the rattling with out breaking the bank.
Old Jun 9, 2005 | 03:05 PM
fcm's Avatar
fcm
Old Fart
Default Re: Sound deadening (SloCrxDx91)
Placing anything, [ weather stripping] between the the plastic trim and the sheet metal chassis will help, some "expanding foam" will help, you must be careful with it, it expands a lot. there is also a roofing material we used to use in the days before the "dynamats" 94
Old Jun 9, 2005 | 03:38 PM
PupaScoopa's Avatar
Default Re: Sound deadening (fcm)
Where are the rattles?
Old Jun 9, 2005 | 05:03 PM
SloCrxDx91's Avatar
Default Re: Sound deadening (PupaScoopa)
I have rattling from the trunk which I used some stuff "just like dynamat" and it worked a little but fell off. I think I will probably buy more of that but I wanted to see if there are any other ways. I used some bed cushion foam inbetween the cardboard speaker cover and the sheetmetal. That does pretty good. I think my window rattles. The roof panel in the back rattles on my 94 accord and I have no clue on how to take that off. The cushion stuff helped but the deadening stuff from a local store didn't seem to do much. I might try putting a few layers on but a I wanna make sure it sticks. I wanted to see if someone heard or has any different things done in the trunk and if anyone has an idea on how to fix the window rattle.
Old Jun 13, 2005 | 08:47 PM
kodou's Avatar
i just went to home depot today and bought some "weatherwatch" insulation. i hope this stuff works on my 4dr.
Modified by kodou at 1:21 AM 6/14/2005
Old Jun 14, 2005 | 06:36 AM
GSteg's Avatar
do it right and buy some real sound deadening material. Although it may work for some, peel 'n seal and such products from home depot may not work as well. They do not stick as well and are not easily flexible. Another thing to note is their dampening abilities. It may be cheaper at first, but to get the same amount of dampening as say Raamat BXT, you'll have to use over 2 layers so in the end, it will actually cost more.
THose products are home depot are asphalt based. They are not going to dampen as well especially with the thin layer. Products such as dynamat extreme, raamat bxt, brownbread, etc are viscoelastic based. They can be molded easier and they stick much better.
But its up to your though.
Old Jun 14, 2005 | 04:11 PM
numbnuts22715's Avatar
Check ebay.. They have some other products. There are a few reviews of those products on HT. I checked into it before. Although most of the reviews said to double layer it all, it still ends up cheaper than dynamat.
Old Jun 14, 2005 | 04:19 PM
jb.'s Avatar
jb.
Default Re: (numbnuts22715)
i bought edead v1se, i havent put it on yet, but i will let everyone know how it goes and how it works. i paid 105 for 60 sq feet
Old Jun 14, 2005 | 05:09 PM
CYM19z's Avatar
Default Re: (jbkiksass69)
its all about B-quite : i have over 70sq ft in my car + another like 10sq ft of dynamat
Old Jun 14, 2005 | 07:02 PM
GSteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbkiksass69 &raquo;</TD></TR><TR><TD CLASS="quote">i bought edead v1se, i havent put it on yet, but i will let everyone know how it goes and how it works. i paid 105 for 60 sq feet</TD></TR></TABLE>
thats some good stuff there. Done right, they are very impressive. I am jealous.
Old Jun 18, 2005 | 09:56 AM
SloCrxDx91's Avatar
That stuff is not that badly priced. I see $30 for 20 sq ft. That should be pleanty for my accord right?
Old Jun 18, 2005 | 03:41 PM
jb.'s Avatar
jb.
Default Re: (SloCrxDx91)
i bought that much for my 95 accord. Im gonna try to do the doors, and the trunk completely. it comes in pieces, not rolls, that are like sheets.
xintegr
Audio / Security / Video
Sep 8, 2007 06:45 AM
m1ndless
May 29, 2007 03:59 PM
themurrell
11
Jan 6, 2007 05:27 PM
flappy188
May 9, 2005 05:38 PM
jiGGaMein
Apr 8, 2002 12:15 PM
