Disconnecting AC, can I disconnect the line from AC hose to Fan #2?
Old Feb 10, 2002 | 04:51 AM
Speed_Ricer99's Avatar
Default Disconnecting AC, can I disconnect the line from AC hose to Fan #2?
OR will that fan not work?
or, is that fan only used for ac?
Old Feb 10, 2002 | 06:56 AM
bryant's Avatar
Default Re: Disconnecting AC, can I disconnect the line from AC hose to Fan #2? (Speed_Ricer99)
The fan will still work just make sure all the wires are still connected up to it and pluged in
Old Feb 10, 2002 | 07:08 AM
Default Re: Disconnecting AC, can I disconnect the line from AC hose to Fan #2? (CR-X)
But thats the thing, the wire that goes to that fan Starts on the metal pipeing. so if i take out that piping there is no where for the other end of the wire from the fan to go to.
Old Feb 10, 2002 | 07:10 AM
bryant's Avatar
What piping are you talking about? the A/C lines? im lost...
Old Feb 10, 2002 | 04:26 PM
racerxadam's Avatar
if you remove the a/c the other fan will never come on anyway it is only used when the a/c is on.
Old Feb 10, 2002 | 05:14 PM
bryant's Avatar
Default Re: Disconnecting AC, can I disconnect the line from AC hose to Fan #2? (racerxadam)
No, the fans come on with no A/C, just not as often. I have both fans with out the A/C and have watched both of them come on before.
axionm1k
Jun 14, 2008 02:16 PM
omgwtfbbqcrx
Apr 21, 2006 12:19 PM
albsgsr
Jul 29, 2005 05:08 PM
blah13
Jun 8, 2003 07:32 AM
rtype11
Jul 11, 2001 10:16 PM
