Suspension & Brakes Theory, alignment, spring rates....
Pulling off front hubs: HELP!!
Old Jun 9, 2005 | 11:53 AM
yh23's Avatar
Default Pulling off front hubs: HELP!!
so I'm taking off the front hubs to have them replaced.
I was able to disconnect everything on the drivers side.
But now, I'm working on the passenger side, and the STEERING wheel bolt/ball joint wont budge and the upper control arm bolt/ball joint wont budge.
WTF. theyre both STUCK. I've tried hammering, using a jack, pulling, YELLING at it, threatening, jumping, punching, etc.
Any tips or ideas on getting the steering and upper control arm disconnected? Any cool trick?
Old Jun 9, 2005 | 11:59 AM
DC4_MADMAN's Avatar
Default Re: Pulling off front hubs: HELP!! (yh23)
Check your other thread.
Old Jun 10, 2005 | 05:06 AM
grnlion's Avatar
are you using a ball/joint separator?
Old Jun 10, 2005 | 10:33 AM
yh23's Avatar
Default Re: (grnlion)
i used a fork, got the steering joint off. but that upper control arm doesnt want to budge. i think im gonna have to remove the battery, take out the whole shock/spring assembly, and then take out the uca.
ya?
Old Jun 10, 2005 | 10:37 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (yh23)
Rent yourself a "Tie Rod Lifter". You can get them at checker auto parts if you rent their 5pc front end service kit. Renting tools is free from there as long as you don't break them (deposit required), and they work great. You can also buy this tool on ebay for like $10 (look up "tie rod lifter"). It works great every single time, and won't damage any part of your balljoints (like forks, and pullers do).
Old Jun 10, 2005 | 02:26 PM
743power's Avatar
Default Re: Pulling off front hubs: HELP!! (4door_demon)
I would yell at them louder.
Old Jun 10, 2005 | 06:41 PM
shortyz's Avatar
Default Re: Pulling off front hubs: HELP!! (743power)
if u got a bottle jack u can wedge that in between the ball joint and upper arm. pops it off.
em96civicex
Suspension & Brakes
Oct 29, 2007 03:51 PM
crazykarlnow
Suspension & Brakes
Sep 1, 2007 10:32 PM
NukeeZoid
Apr 10, 2007 03:11 PM
DougieStyle
Suspension & Brakes
Jul 12, 2006 11:07 PM
yh23
10
Jun 10, 2005 10:32 AM
