Car not going into gear on the ground but is when off the ground.. help
Old Jun 9, 2005 | 11:06 AM
seeeya04's Avatar
Default Car not going into gear on the ground but is when off the ground.. help
OK i did the ls swap in to my civic
and when my car is on the ground with the motor OFF my car goes into all gears even reverse.But when the car is on the ground with the motor ON it does not go into gears..
but when my car is off the ground it goes into all gear's with motor ON OR OFF..
axles are ok
we took apart the tranny from motor and everything seems to be fine..nothing stuck or misplaced...
any help would be greatfull thanks
Old Jun 9, 2005 | 11:54 AM
snatch's Avatar
Default Re: Car not going into gear on the ground but is when off the ground.. help (seeeya04)
When you took apart the tranny from the motor, did you inspect your clutch? Sounds like the clutch isn't disengaging. Clutch pedal still have pressure as well?
Old Jun 9, 2005 | 11:56 AM
Crasian's Avatar
Default Re: Car not going into gear on the ground but is when off the ground.. help (******)
in my dads accord, when the clutch started to go it would not go into gear easily at all :S
Old Jun 9, 2005 | 12:42 PM
snatch's Avatar
Default Re: Car not going into gear on the ground but is when off the ground.. help (FarOutCoupe)
Well I've heard before of people who have problems getting the car into gear when the engine is on, but when it's off it works ok. Very similar to this fella's situation.
Old Jun 9, 2005 | 12:58 PM
seeeya04's Avatar
anyone else
Old Jun 9, 2005 | 03:53 PM
seeeya04's Avatar
ANYONE ELSE PLEASE
Old Jun 9, 2005 | 04:28 PM
DelSol-B-18's Avatar
Hey. I can 99.99% guaruntee that it is ur clutch OR/AND Flywheel I did a swap in my car and same thing happend, when it was shut off would go into all gears but with engine running nOTTIN, i could rabbit start ( start in 1st gear and take off, but no shifting,) with car jacked up would go into gear with car running, bc when ur tires are off the ground the tires will even slightly move with car in nutural there is no weight on them check ur clutch, T-O bearing etc.. Small things will make BIG problems, also check ur Flywheel once we got the new clutch in it still did same thing ended up being the flywheel was warped a VERY lil bit but would not allow the clutch to engage...
Old Jun 9, 2005 | 04:40 PM
seeeya04's Avatar
Default Re: (DelSol-B-18)
Ok thanks man hey ill cheak it out and ill let you know if it worked or not thanks
Old Jun 12, 2005 | 10:00 AM
seeeya04's Avatar
anyone help i know its my shift linkage but how do i fix it
Old Jun 12, 2005 | 10:04 AM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 &raquo;</TD></TR><TR><TD CLASS="quote">anyone help i know its my shift linkage but how do i fix it </TD></TR></TABLE>
Your shift linkage? I'm not seeing how that would cause this problem.
Old Jun 12, 2005 | 11:43 AM
G U E C O's Avatar
it cant be a clutch problem. a clutch problem would let you get in to all gears easier and sometimes you dont need to press the clutch pedal to get in gear if the clutch is completely gone.
Old Jun 12, 2005 | 11:48 AM
JDM-97CX's Avatar
Default Re: (stock93cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx &raquo;</TD></TR><TR><TD CLASS="quote">it cant be a clutch problem. a clutch problem would let you get in to all gears easier and sometimes you dont need to press the clutch pedal to get in gear if the clutch is completely gone. </TD></TR></TABLE>
Not if the clutch wont disengage. If it wont disengage then there is no way it will slide itno the gears easier. There is more than one type of clutch problem.
Old Jun 12, 2005 | 05:53 PM
seeeya04's Avatar
Default Re: (JDM-97CX)
I so what do you guys think that its my linkage binding up when my car is on the ground
Old Jun 12, 2005 | 06:40 PM
snatch's Avatar
Default Re: (seeeya04)
Why would you think your linkage is binding up when your car is on the ground? The geometry of the linkage would not change when the car is on the ground or in the air.
Old Jun 12, 2005 | 07:22 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 &raquo;</TD></TR><TR><TD CLASS="quote">I so what do you guys think that its my linkage binding up when my car is on the ground</TD></TR></TABLE>
this guy dosent want help. i've seen his question answer so many times check your clutch maybe u but the throw out bearing in wrong. the sfift linkage will not bent and if it does then its broken
Old Jun 13, 2005 | 04:18 PM
seeeya04's Avatar
Default Re: (street dreams)
We got the prob fixed it wanst nothing you guys stated..
the lever needed to be lubricated haha..
Old Jun 13, 2005 | 04:47 PM
MrPotatoeHead's Avatar
You are an ungreatfull person...NO thanxs all for helping.....I suggest no-one help this guy again........
Modified by MrPotatoeHead at 8:41 PM 6/13/2005
Old Oct 21, 2023 | 11:59 AM
ajr181's Avatar
what needed to be lubricated??
Old Oct 23, 2023 | 02:43 PM
DaX's Avatar
DaX
Loved
Community Favorite
It's been 18 years....doubt he'll answer. But maybe he was talking about the shift linkage?
90sedan
Sep 24, 2008 07:57 PM
B-SerioUs EGg
Dec 23, 2005 11:36 AM
locass316
May 13, 2003 08:53 AM
vtec69
Apr 1, 2003 04:19 PM
sean96gsr
Mar 2, 2002 09:38 AM
