squeaking noise coming from clutch pedal
Old Jun 9, 2005 | 10:05 AM
Goodbye My Love's Avatar
Default squeaking noise coming from clutch pedal
got a 93 dx hatch, everytime i step on the clutch pedal, it seems to squeak and even though the car is turned off i still can hear it, im not sure if it's the clutch pedal's cable or i just have to add powder graphite into the master slave cylinder.
Old Jun 9, 2005 | 10:25 AM
92BluEH-3's Avatar
lulz
yea that happens on mine but i have a bad clutch so i think that you pressure plate might be bad im not sure or its just that it is weak
Old Jun 9, 2005 | 10:46 AM
GUNNER666's Avatar
Default Re: (92'BluV-tecHatch)
mine does the same, been like that for 2 years, i pretty sure it's the cable, that is rusty.
Old Jun 9, 2005 | 11:21 AM
ITLNstallion818's Avatar
Default Re: (GUNNER666)
clutch master cylinder going bad probably, mine does that too...
Old Jun 9, 2005 | 11:50 AM
BiffStroganoffsky's Avatar
Mine was squeaking under the dash and I got it to stop by cleaning the gunk off the exposed piston/rod and lubbing it. It got rid of the squeaking but my shifts were still bad so I'm having to get a tranny/master/slave transplant.
On that note (quick hijacking): what's a reasonable price for a used D series tranny?
...back to your regularly scheduled programming...
Old Jun 9, 2005 | 12:49 PM
UberMunkey's Avatar
agreed, clutch master is probably it
Old Jun 9, 2005 | 01:23 PM
MiMiK's Avatar
Default Re: (UberMunkey)
eek... mine does that too. butonly when my car is cold..
-sorry to be a thread hi-jacker..
Old Jun 9, 2005 | 01:47 PM
BauleyCivic's Avatar
Risky Business
Default Re: (MiMiK)
All 3 of our civics do it (93, 99, 01)...its normal, mine has done it with 3 different clutches
Old Jun 9, 2005 | 01:52 PM
94sohcVTEC's Avatar
Default Re: (BauleyCivic)
I got clutch creaking in cold temp AND roof creaks during hot temp. Del sols got issues all year round.
Mohsin's Avatar
had a full clutch kit (exedy organic) and fidanza flywheel installed, squeeky noise happens mostly when cold, i can feel it right under the pedal.
Mohsin
Old Jun 9, 2005 | 05:45 PM
futurefastguy's Avatar
Default Re: (Mohsin)
lol, my '92 hatch has the same squeak when i press on the clutch.
Old Jun 9, 2005 | 06:15 PM
PinkMaggit's Avatar
Default Re: (futurefastguy)
tranny price 100-250 depending on mileage n type
Old Jun 9, 2005 | 06:52 PM
HondaHemp's Avatar
Default Re: squeaking noise coming from clutch pedal (Longliveeg6)
OK, a little info on clutch squeaks... The clutch fork has to pivot when engaging and disengaging the clutch, therefore you have to have lubrication on all pivot points of the fork. Put some wheel bearing grease where there is metal to metal contact of the clutch fork and you will have a very quiet and smooth operating clutch. If you dont then you will probably be replacing parts on your trans.
Old Jun 18, 2005 | 09:10 AM
Default Re: squeaking noise coming from clutch pedal (HondaHemp)
Where would i apply the wheel bearing grease, for exx, underneath the car?
DulinDragons
Dec 17, 2009 06:50 PM
K-Spec
Sep 26, 2006 11:30 PM
delsolb16
13
Oct 1, 2005 11:09 AM
JSIR
May 2, 2005 01:14 PM
The Mole
Apr 3, 2002 08:46 PM
