Time For New Oil Rings. Jdm Pistons at the same time?
Old Jun 9, 2005 | 10:05 AM
Elwapu's Avatar
Default Time For New Oil Rings. Jdm Pistons at the same time?
My 2000 has 74,000 miles now and the oil rings have just taken a dump, I have the motor out and I'm going to Aj this Saturday to pick up some toys, final drive etc... I was thinking about throwing in some jdm pistons while I've got it apart. What are your opinions on this and what kind of gains should I expect from pistons and a spoon head gasket? Current mods are an AEM, Comptech Race header, Spoon Exhaust. Thanks for your help.
Old Jun 9, 2005 | 10:23 AM
Bbasso's Avatar
Default Re: Time For New Oil Rings. Jdm Pistons at the same time? (Elwapu)
do you have plans and money to use a engine management system?
It would not be such a bad idea. remember your changing the way the motor works and what the stock ECU was designed for.
Old Jun 9, 2005 | 10:28 AM
Elwapu's Avatar
Default Re: Time For New Oil Rings. Jdm Pistons at the same time? (Bbasso)
Yeah I have a safc currently sitting in my garage never used, I was thinking that I can use that for now and possibly hondata down the road.
Old Jun 9, 2005 | 10:30 AM
Dave_B's Avatar
I would get the hondata if this is what your looking at doing. Might as well do it right.
Old Jun 9, 2005 | 10:36 AM
RTW DC2R's Avatar
whats the difference between USDM and JDM ITR pistons? I cant see it being that much but Im not sure. Also, if you want to use a thinner head gasket, just use an OEM gasket and remove the middle layer and save a few bucks. In any case Im assuming that you will bump your compression only slightly and shouldnt need any major EMS to tune with. I dont know the limitations of the safc but if it allows you to tune fuel I think you will be fine with the stock ECU. Obviously you will get best results with a full stand alone EMS but I doubt its a necessity at this point. I have a thin head gasket with some slight headwork with stock ECU and it runs great with NO tuning device.
Old Jun 9, 2005 | 11:03 AM
Educator's Avatar
Default Re: (RTW)
10.6:1 vs. 11.0:1
Old Jun 9, 2005 | 11:08 AM
itralex's Avatar
Default Re: (Educator)
Run some CP's instead with your choice of compression
Old Jun 9, 2005 | 11:38 AM
Elwapu's Avatar
Default Re: (itralex)
I want to use oem parts as my goal isn't an all motor monster. Inline four said that between the pistons and spoon head gasket I should notice roughly 10-15 to the wheels once it's tuned. I guess I can see it as a possibility since I would be going from 10:6 to roughly 11:3 compression ratio.
Old Jun 9, 2005 | 03:06 PM
Mythias's Avatar
Default Re: (01PY0559)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PY0559 &raquo;</TD></TR><TR><TD CLASS="quote">I would get the hondata if this is what your looking at doing. Might as well do it right.</TD></TR></TABLE>
I just so happen to know someone selling a hondata.
Old Jun 10, 2005 | 02:04 AM
sylvain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Educator &raquo;</TD></TR><TR><TD CLASS="quote">10.6:1 vs. 11.0:1</TD></TR></TABLE>
No, 11.1:1
xQB21x
Dec 18, 2009 04:54 AM
oilguzzler
Mar 14, 2006 09:13 AM
OMG WTF
Feb 19, 2006 11:16 PM
ActiveAero
Jan 2, 2004 11:51 AM
princeallure
Aug 25, 2002 10:48 PM
