Weird electrical problem - - 95 cx
Old Jun 9, 2005 | 09:11 AM
-[95cxhatch]-'s Avatar
Default Weird electrical problem - - 95 cx
So far I've been lucky and haven't had any problems with my new hatch until now. Yesterday I got in my car pushed in the clutch cranked the key and accidentally released the clutch for a split second but immediately pushed it back down, this caused the safety switch on the clutch pedal to turn on/off/on in a fast sequence. Now the car is totally dead electronically with the key off. Here is the weird part If I turn the key forward one notch to the acc position my instrument cluster lights come on really dim and slowly get brighter but this is only after I turn my headlights on If I don't turn my headlights on the car is dead in the acc position. When I try to crank over the dash lights go off and the solenoid clicks like there is not enough voltage to start the car.
I've checked every fuse under dash and hood all checked out ok. The battery has 13.6 volts sitting in the car. The only thing left I can think of is the main relay. Could his be my problem and is there anyway to test it?
Time to sift through wiring diagrams until I get a response on here
I'm totally lost here any ideas are greatly appreciated!
Old Jun 9, 2005 | 10:49 AM
Default Re: Weird electrical problem - - 95 cx (-[95cxhatch]-)
ok well, I just changed the starter and that did nothing...
Old Jun 9, 2005 | 11:12 AM
bump for some help I'm lost here
The main relay is clicking on and off when I try to crank the car over but something is draining a large amount of my voltage
Old Jun 9, 2005 | 11:20 AM
Default Re: (-[95cxhatch]-)
also jump starting the car does nothing I put my 100 AMP jump start charger on the battery and crnaked it over for about half a second before it fails again
Old Jun 9, 2005 | 12:18 PM
Relic1's Avatar
with a volt meter make sure there is power at the fuel injectors. (yel/blk wires is ignition power) AND if you can hear the fuel pump when you first switch on the key. then the main relay is fine.
I'd bet you popped a ground wire by drawing so much power to the starter.
Old Jun 9, 2005 | 01:36 PM
well after doing a load test on my battery I determined it was faulty so I replaced it and the car is running perfect now so hopefully the battery was my only problem but I'm keeping my eyes and ears open
jwatsoncrx91
Sep 19, 2012 05:25 PM
yellowxhoodie
Nov 7, 2009 04:24 AM
patrickstar
Apr 23, 2009 10:28 PM
EBPSI
Mar 12, 2007 02:02 PM
Freshsho
Dec 20, 2005 08:03 AM
