93 accord sedan swap?
ok i have a 93 honad accord ex with a 2.4 l sohc. what is the best low price motor i should swap it with. reason for swap is blown motor. i was thinking of H22 but I kinda wanna keep it under a grand. any help and/or advice please!
93 accord with a 2.4 SOHC??? i thought they had 2.2 SOHC. But anyway yea H22 is a good swap but its gonna cost you a lot more than a grand. If you want a motor around a grand you can always try to turbo the stock motor. That would be the cheapest method. I dont think you can find any other motors for under a grand. Maybe an F22B1 but im not sure <feel free to correct me>. But i think turbo is the way to go for that 2.2 if u want to spend under a g.
Its not an actual turbo kit its kinda like a donor kit from a mitsubishi eclipse. Theres a dood runnin it on CB7tuner.com. Sorry I lied its 1200 dollars. He fabbed most himself but i think it would be a good option if ur plannin to spend around 1g and dont feel like spendin extra cash for the H series swaps.
http://www.cb7tuner.com/vbb/sh...Turbo
Modified by NAiL05 at 3:21 PM 6/9/2005
i wanted to do the same swap on my accord also cuz of a blown motor
but got another stock one with wayyyyyyyyyyyyyyyy less miles on it then my original had... i heard the swap can cost around 2500 with all the stuff that u would need... so i just went with another stock one... cant beat 100 bux
Well, I'm looking at a H22A: motor, tranny and computer for $1950. It doesnt sound to bad to me. But then on the same web page theres a H22A (same motor) with just the motor without the tranny and ecu for 1200 bucks. Tranny only costs 150 and the ecu only costs 100.
Will any B series motors fit in there correctly without mounting kit and wiring kit?
And now im looking at another great deal check this:
H22A for $2199
- Motor
- Hydraulic Tranny
- ECU (P13)
- Axles with Half Shaft
- Shifter Cables
- Shifter Assembly
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300) <---whats that???!?!?!?
H22A for $2199
- Motor
- Hydraulic Tranny
- ECU (P13)
- Shifter Cables
- Shifter Assembly
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
There is no point in putting a B series motor into an Accord. You will be lacking torque. Plus accord is a heavier car and needs a bigger motor to push it so stay with the h series or f series motors.
