short shifter help
i just installed a ractive short shifter..and it came with 2 extra bushings or o-rings..so i put them in rite..now my shifter is super stiff ....wat do i do to make it smooth...it even makes a squeeky sound wen i shift gears ....should i take those extra bushings out ? please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batzcivic »</TD></TR><TR><TD CLASS="quote">i just installed a ractive short shifter..and it came with 2 extra bushings or o-rings..so i put them in rite..now my shifter is super stiff ....wat do i do to make it smooth...it even makes a squeeky sound wen i shift gears ....should i take those extra bushings out ? please help</TD></TR></TABLE>
The bolt that goes through the shift rod and and shifter is probably too tight, back it off a 1/4 turn and see if it lossens up a bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon »</TD></TR><TR><TD CLASS="quote">
there you go, lossen the bolt and it should be alot looser
please tell me you greased the ball on the shifter
-if you did, then yeah loosen it up a bit like others have said. My shifter is alot firmer tham oem, but its smoother.
BAZ
Jul 29, 2003 09:29 PM
