just got my 23 mm rear sway anything special i need to know?
Old Jun 8, 2005 | 11:06 PM
PY 01-0972's Avatar
Default just got my 23 mm rear sway anything special i need to know?
got it with new bar bushings just a pretty straight forward R & R job? my car has 29,600 on it re using the endlink bushing is ok? thanks again for all the replies
Old Jun 9, 2005 | 06:06 AM
Bbasso's Avatar
Default Re: just got my 23 mm rear sway anything special i need to know? (PY 01-0972)
read : https://honda-tech.com/zerothread?id=100159
Old Jun 9, 2005 | 06:55 AM
PY 01-0972's Avatar
read that the other day thanks! that was the final selling point for me just wondered about the install
Old Jun 9, 2005 | 07:23 AM
splitime's Avatar
Default Re: (PY 01-0972)
Unbolt old... bolt in new.. leave the couple bolts loose and lower the back end down (only if you can reach under and finish tightening).
Ideally you preload the bar equally on both sides by either lower car down or jacking the lcas up an equal amount. That way the bushings are tightened down with all areas equal.
Old Jun 9, 2005 | 08:47 AM
PY 01-0972's Avatar
thanks
ian1006
Honda CR-V & Element
Jan 25, 2014 03:41 PM
im_inn0c3nt
Jul 16, 2010 09:52 AM
$LiLPooky$
Oct 6, 2005 09:48 AM
Flux
Jul 1, 2004 03:59 PM
Pat
Aug 30, 2001 07:43 PM
