did dx to si swap
Old Jun 8, 2005 | 10:27 PM
unlimited6986's Avatar
Default did dx to si swap
but the car wont turn over and when it does it just stops. IDk what's wrong with it also when the car turns over out of the header smoke comes out and smells like firework's does anyone know what could be wrong?
Old Jun 8, 2005 | 10:30 PM
solareclipseauto's Avatar
Default Re: did dx to si swap (unlimited6986)
check your wiring
Old Jun 8, 2005 | 10:32 PM
we checked it twice and everything is good
Old Jun 9, 2005 | 12:17 AM
NikoZai's Avatar
Default Re: (unlimited6986)
Car won't turn over?
That means your starter is bad... If it turns over but doesn't fire.. thats not called "won't turn over".
That's called "won't fire"
Otherwise, ounds like you're flooding the engine, it's burning in the exhaust, and your exhaust manifold gasket is shot if smoke manages to come out at the head. (it you mean at the tailpipe, thats ok.)
Are you leaking fuel at the injectors?
Could be your firing order, could be the distributor itself. Or your distributor wiring.
What codes are you getting after you crank it over a few times?
Old Jun 9, 2005 | 08:43 AM
the car turns over a couple times but when it does after a sec it stops and thats it
Old Jun 9, 2005 | 08:59 AM
crxtreme89h's Avatar
Did it turn over before you did the DX to SI swap?
I would check the Ignition starter switch. Located on the backside of where you put your key in to start the car.
Old Jun 9, 2005 | 09:01 AM
when i had the dx engine in it started fine i was riving it when i put the si engine in it did this ill check the ignition
icedlee
May 22, 2005 12:39 PM
oldskool4life
13
May 15, 2005 01:58 PM
CHAPY
Apr 15, 2005 09:03 AM
vtec_powah
Aug 1, 2001 07:58 PM
vtec_powah
Jul 31, 2001 07:45 PM
