Whats wrong with this?
Old Jun 8, 2005 | 10:17 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Whats wrong with this?
Ok well i wasnt expecting much, only about 180-190 but what the hell is wrong with this.
B16
Crower 404 cams
Arias 12.1 shelf piston, w head gasket running 12.7 cmp
Golden eagle rods
ROcket motorsports Valvetrain
All new gasket, bearings
Moroso Race dizzy
Head bolts
Rod Bolts
RC 310's
Micropolished and balanced crank
Block and head were hot tanked with a very small mill
I/H/E
Ys1 Tranny with 9 lb flywheel, and ACT extreme clutch kit
VAFC
J's Racing chipped P28
B&M FPR
SKunk 2 cam gears.
Ok well off the Dyno it made 160whp/110 Ft Lbs
Thats terrible, it def feels faster than that.
Somebody help me out with figuring out where i went wrong. Its kind of a killer to throw together a decent motor and have it Dyno around stock Gsr Numbers.
Old Jun 8, 2005 | 10:23 PM
onepoint6i's Avatar
Default Re: Whats wrong with this? (Mattb16teg)
what header you running? what are your compression psi numbers? what octane fuel?
Old Jun 8, 2005 | 11:25 PM
JUN-DA6's Avatar
check fuel pressure, dyno tune VAFC, check cam gears timing match to Crower 404 cams, and try to run race fuel to see makes any different.....good luck
Old Jun 8, 2005 | 11:32 PM
onepoint6i's Avatar
Default Re: (JUN-DA6)
yup, he said he dynoed 160HP, he didnt specify if it was tuned..im assuming it was tuned and only made 160hp??? right?
what was the baseline run before tuneing?
Old Jun 9, 2005 | 03:15 PM
Mattb16teg's Avatar
Community Builder
Default Re: (1.6i)
thats the thing, i think i need to go to a better shop to get tunning, because it baselined at the same. They said they only gained Mid range power and a few ft lbs. running a shitty Trust header. I thinking the ECU im running is messing me up. Apparently its for a two liter set up. but I dunno. At this point I feel like giving up, and/or just spraying the **** out of it.............
Old Jun 10, 2005 | 09:00 AM
v-6 hatch's Avatar
Default Re: (Mattb16teg)
as rich as that bitch was runnin on the dyno spray the mess out of it
vtecinmyvains
24
Jul 31, 2009 08:50 AM
dc r-spec
Mar 1, 2006 08:44 AM
hype r 555
41
Oct 15, 2004 10:05 AM
Teal95Coupe
Mar 21, 2003 10:52 PM
96b18c
Sep 15, 2001 07:57 PM
